DIGI...Tech Support Utility error
i get the following message when i try to start the utility...
there does not appear to be a valid installation of pro tools. press any key to continue.... my 7.4cs2 installation runs GREAT!!!! no problems with PT just the utility. i've checked the registry just to make sure nothin' is hosing it up but i'm at a loss now. it would be nice to be able to use the utility if needed. any insight???? thanks
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Re: DIGI...Tech Support Utility error
bump
DIGI????
Do you have Pro Tools installed somewhere other than the default location?
mykhal c,
I had this same problem/same error message trying to run the utility. What works for me, and I have no idea why, is to run the utility from the desktop. Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
I get that message from the utility if I run it on a computer that doesn't have Pro Tools installed, so it's definitely having trouble finding your installation for some reason.
Do you possibly have a system that has a co-install of both WinXP and Vista?
If so - we're seeing this error in those cases and, at the moment, there isn't a fix or workaround. We're looking into getting it revved so that it works on those configs. |
EDIT spkguitar, appreciate you dupping the problem on your non PT system
no. but i DO have a dual boot XP system. both partitions do have PTLE installed also. are you cats seein' the problem with dual boot XP systems also????
Tech Support Utility — The Latest? | innermusic | Pro Tools 10 | 1 | 03-30-2012 05:32 AM |
Tech support utility in PT8 | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-26-2008 08:42 PM |
Tech support utility app problems help! | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-04-2008 09:30 PM |
Runtime C++ error w/list from tech support utility | Retinal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-18-2008 06:48 PM |
Tech support utility | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-04-2007 12:00 AM |
