Old 02-23-2011, 03:31 AM
Ph.D Ph.D is offline
Default Sound Issues - static/fuzzy?
Hey everyone,
I'm hoping I don't have a major issue here?
I have connected 11R to my 003 rack and things were going fine. I turned it on tonight with the 003 to have a play around and do a bit of recording, and I now have a static and fuzzy guitar sound, on distorted amps/effects and clean sounds...it's on every amp simulation. A real noticable static covering the sound.
The hardware, playback engine, I/O set up is all good. The guitar lead is fine, same as headphones and monitors. I have touched nothing since last time when it was working fine, and now I turn it on and this.
It arrived on my doorstep with a major clocking issue, I was without it for weeks while it was fixed over the chrissy period, haven't had it back long and now this. I truly hope this is something simple.
Any help at all will be much appreciated.
Edit: Well, I turned everything off and then booted back up again and no problem now...strange? At the time when it happened I forgot to try the 11R in standalone mode, to try and eliminate the problem, to see if it was a 11R or 003 or connectivity issue. But anyway, it seems to work fine now...'Now' being the operative word here. Has anyone had any similiar issues?? The 11R arriving on my doorstep with major issues has unfortunately put me on edge, and this definitely doesn't help...
Pete
Pro Tools LE 8 003R+, Macbook Pro 13", M-Audio Profire 2626, Eleven Rack
PT10 Sound goes fuzzy / distorted randomly; also get hard freezes dan0082 Windows 2 10-19-2013 01:37 PM
Fuzzy Static with ProTools playback and window media files playback 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2011 06:41 PM
constant NOISE sound and Static/Poping sound jaynyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2007 11:10 PM
Exported mp3s have fuzzy sound quality JBlancato 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-14-2003 08:59 AM
Burned CD's sound fuzzy... elijahsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 10-24-2002 07:30 PM
