problems since 8.0.4 came to town 8^( sandra included
could someone maybe point me to where by bios settings should be for an i5 system? i havnt really done anything they are default... is there changes that should be made? i have read some post about issues with i7 and bios settings but nothing on i5?
thanx in advance been having alot of buffer errors and fuzzy distortion since 8.0.4 everything was lovely for the most part with 8.0.3 and the beta drivers....just couldnt go below 256 buffer....and i was stupid and deleted the beta driver from my system.....like i said i was stupid..... oh... and i am recording to a second drive ......wd caviar black SiSoftware Sandra Computer Model : Dell Inspiron 580 Workgroup : WORKGROUP Host Name : wayne-PC User : wayne Processor Model : Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz Speed : 3.33GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 4 threads sharing Computer Mainboard : Dell 033FF6 BIOS : Dell A02 11/30/2009 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR3 Chipset Model : Dell Core (Auburndale/Clarkdale) DRAM Controller Front Side Bus Speed : 1x 133MHz (133MHz) Total Memory : 8GB DIMM DDR3 Shared Memory : 34MB Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-G7 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-G7 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-G7 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-G7 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-20 4-27-8-4) Video System Video Adapter : NVIDIA GeForce GT 220 (32 SM4.1 1.34GHz, 1GB DDR3, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce GT 220 (48SP 6C 1.34GHz, 1GB) Adapter : NVIDIA GeForce GT 220 (48SP 6C 1.34GHz, 1GB) Adapter : NVIDIA GeForce GT 220 (32SP 1.34GHz, 986.6MB) Storage Devices WDC WD1001FALS-00J7B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:) (I:) WDC WD1001FALS-00E3A0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (K:) Generic-Compact Flash (USB) : N/A (E:) Generic-SM/xD-Picture (USB) : N/A (F:) Generic-SD/MMC (USB) : N/A (G:) Generic-MS/MS-Pro/HG (USB) : N/A (H:) V88 V88 1GB (USB) : 961MB (J:) TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices RECOVERY (I:) : 15GB (NTFS) @ WDC WD1001FALS-00J7B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Removable Drive (J:) : 961MB (FAT) @ V88 V88 1GB (USB) jerrywc (K:) : 932GB (NTFS) @ WDC WD1001FALS-00E3A0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) OS (C:) : 917GB (NTFS) @ WDC WD1001FALS-00J7B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Removable Drive (E:) : N/A @ Generic-Compact Flash (USB) Removable Drive (F:) : N/A @ Generic-SM/xD-Picture (USB) Removable Drive (G:) : N/A @ Generic-SD/MMC (USB) Removable Drive (H:) : N/A @ Generic-MS/MS-Pro/HG (USB) Optical Drive (D:) : N/A @ TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell H57 LPC Interface Controller LPC Legacy Controller 1 : T2 87-21 Audio Device : Dell P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : nVidia High Definition Audio Controller Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Disk Controller : Dell P55/PM55/3400 4 port SATA IDE Controller Disk Controller : Dell P55/PM55/3400 2 port SATA IDE Controller USB Controller 1 : Dell P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Dell P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Peripherals Media Player : () Media Player : () Media Player : () Media Player : () Media Player : V88 V88 (960.72MB) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index |
Re: proper BIOS settings for an i5 system? HELP!
bizzzump
To be able to give you any kind of proper advice, we would need to know specifics about your system. "an i5 system" is too, too generic. That's kind of like saying "my blue car is broken, what do I need to fix it?"
We need the sandra report. Before you go mucking around with your BIOS, you should first make sure that you have all the requirements met for running Pro Tools. That includes having a separate physical hard drive for audio sessions.
like i said in the post i do have a seperate hard drive.... the one everyone seems to recomend....
and the specs that are at the link is my exact computer....the only thing on it is pt 8.0.4 what else could you need to see? Dell Inspiron i580-5108NBC Review User reviewsSpecificationsCompare.ShareAdd to my listPrintE-mailYahoo! Buzz .Manufacturer: Dell, Inc..Part Number:i580-5108NBC..General Built-in Devices Keyboard , LED panel .Width 6.9 in .Depth 17.4 in .Height 14.8 in .Weight 17.4 lbs .Desktop type Gaming system .Processor Type Intel Core i5 650 / 3.2 GHz .Cache Memory Installed Size 4 MB .RAM Installed Size 8 GB .Technology DDR3 SDRAM .Storage Hard Drive 1 TB - Standard - Serial ATA .Optical Storage Type DVD+/-RW / CD-RW .Storage Removable Type None .Graphics Controller Graphics Processor / Vendor NVidia GeForce GT 220 .Video Memory 1 GB .Audio Output Type Sound card - Integrated .Networking Networking Network adapter .Expansion / Connectivity Expansion Bays Total (Free) ( 1 ) x External - 3.5 in , 5.25 in .Expansion Slots Total (Free) Memory , Memory card reader , PCI , PCI Express x1 , PCI Express x16 .Interfaces 6 x USB 2.0 - USB 2.0 , Ethernet - RJ-45 , HDMI .Miscellaneous Cables Included Power cable ( 1 pcs.) .Features 802.11b/g/n Wireless LAN .Operating System / Software OS Provided Microsoft Windows 7 Home Premium .Software Drivers & Utilities , Microsoft Works .Sustainability Greenpeace policy rating (May 2010) 4.3 .Compare prices for Dell Inspiron i580-5108NBC As shown: $799.99 |
The exact stuff that the Sandra report is going to show us!
That's why we ask for it.
looks like the stuff that i posted above is pretty much the basic stuff that is on the sandra.....
can someone at least tell me if they see a problem there? or at least somthing in the bios i might need to change in general? this stuff is driving me crazy!!!!! i mean its a dell.... should be pretty black and white what is on the inside...especially to you guys!? (and i know i have read some bad things about dells) so if someone sees a troublesome component........please! |
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Really. Basic details can only give so much. We need chipset information, and other smaller details that are generated by a system report. It only takes a minute to install Sandra and post the report. A minute that can save you a lot of time and hassle, and helps us to help you.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
"I've got some change in my pocket; how much is it?"
"It's the standard change; quarters, dimes, nickels, and pennies. How much do I have?" See... unless I tell you there are 3 quarters, 4 dimes 2 nickels and 5 pennies, you would never know how much change I have. Anything else would be a guess. It's the same thing with your computer. Unless you give us the information we are asking for... anything we say would be a guess. Dell is one of those companies that changes the specs frequently on their computers without changing model numbers. The specs on that machine you listed to might be COMPLETELY different than the machine you are actually trying to use (yep, even if you bought it a couple of days ago!) I'm also not sure why you would need this information so immediately; you're not even near your computer (by your own admission, you are at work) so you wouldn't even be able to try out anything that we would suggest, so...
thanx for all of the help!
im gonna get you a sandra when i get home.... Quote:
in the mean time maybe someone could take a look at this: http://l7world.com/2010/05/dell-insp...tency-fix.html dpc latency? Quote:
Pt9.0.5 Help Please (Sandra Report Included) | msuk | Windows | 2 | 09-25-2011 08:48 AM |
Three problems since 8.0.4 - Sandra report included. | David Sabine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-22-2010 10:44 AM |
Playback Engine Problems!! SANDRA INCLUDED PLEASE HELP!!! | Troy Tracks Studio | Pro Tools M-Powered (Win) | 2 | 05-13-2010 07:03 AM |
Help with a new system please (Sandra included) | hootist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-27-2010 08:15 AM |
Random MIDI OUT problems on Rack 003 PT8 XP - SANDRA Report Included | dogstarism | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-14-2010 06:04 PM |
