Blue Arrow by the Timeline Insertion Marker
Hey guys need some help here, i have been doing a session and for whatever reason i lost my blue solid arrow that you can place anywhere in the Timeline next to my Timeline Insertion Markers. I so rely on that with punch ins and such and also listening back to certain parts of the songs within my yellow markers. Is there a key command that i can punch so i can get it back on my Timeline. I trashed my perferences and rebooted along with going into the preferences and seeing if i have to mark a box in order to appear in my sessions and i cant find it to save my life. I have PT version 7.3.2cs Mbox 2 with a Glyph External Hardrive recording my audio. Below is my Terra Digital Audio ML12 Laptop specs. Thank you so much in advance for any advice you can give me.
• Processor: Intel® Pentium® M 2.0GHz processor • Memory: 2GB DDR2 533 MHZ SDRAM • Motherboard: Front Side Bus: 533MHz, Cache: 2MB (Supports up to a 2.5Ghz processor) • Video Card: ATI Mobility Radeon X700, 128MB • System Hard Drive : 2.5-inch 9.5mm 80GB IDE HDD* • Optical Drive o DVD/COMBO: CD-R/RW:24X/24X, CD-ROM:24X, DVD-ROM:8X o DVD-Dual Double Layer Module: DVD-R/RW: 4X/2X or 8X/4X DVD+R/RW: 4X/2.4X or 8X/4X, CD-R/RW: 16X/10X or 24X/10X, DVD-ROM:8X, CD-ROM: 24X o Support Module Warm Swap Function and 2nd HDD/2nd Battery • Card Reader: Built-in card reader support (SD/MMC/MS/MS PRO), PCMCIA 2.1 compliant • LED Status Indicator: Power-on/Suspend, Battery Charging/full/low, Storage device access, Capital Lock, Number Lock, E-mail in box, Wireless indicator, Audio DJ Activity • Audio: Intel High Definition Audio Chipset with 3D Effect & Full Duplex, SoundBlaster PRO compatible, Built-in stereo speaker and Microphone • Ethernet: Intel High Definition Audio Chipset MODEM and Gigabyte LAN on board, Intel Pro Wireless (B/G) • Interface o 1 x EPP/ECP Parallel port/D-sub 25-pin o 1x Port Bar III 68-pin Connector o 1 x PSMCIA slot o 1x Infrared port support IrDA V1.1 o 1 x TV-Out o 1 x Headphone-out combo jack o 1 x Microphone-in jack o 1 x VGA port/Mini D-sub 15-pin for external DDC monitor o 1 x RJ11 Modem jack for phone line o 1 x RJ45 LAN Jack for LAN insert o 4 x USB 2.0 ports, 1 x IEEE 1394 port • Battery Pack & Life o Li-Ion 8 cells, 14.8V, 4400mAh, 65WHr battery pack o Swappable Second Battery Support (Using Optical Drive Bay) o Run-down life, 4.5-5.5 hrs (6.8-8.5 hrs with the 2nd Battery, subject to different specifications • AC Adapter: Output: 19 V DC, 3.42 A, 65W, Input: 100—240V AC, 50/60Hz universal • Dimension & Weight : 354 x 273 x 22-34 mm(WxDxH,) , 2.6 KG (with traveler’s drawer, without ODD) • Security: BIOS Booting / HDD User Password, Kensington lock hole provided • Operating System: Windows XP Professional SP2 low you will see the specs of my laptop. THank you so so much for the needed help. |
Re: Blue Arrow by the Timeline Insertion Marker
Sorry guys i actually have version 7.3.1cs5 sorry again for the typo
Are you talking about the Time base rulers? or the cursor? hard to say.
Go to page 96 and 97 of the PT REF Guide and get the name of it. or To display all Edit window view options: Select View > Edit Window > All.
Camilo Toledo |
Down arrow key insertion timing accuracy? | reichman | Post - Surround - Video | 6 | 03-14-2012 01:54 PM |
Blue arrow in timeline | jefflennan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-17-2009 08:57 AM |
Timeline insertion | jandue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-18-2007 03:19 PM |
Moving insertion point to next marker? | IO Composer | Pro Tools TDM Systems (Mac) | 2 | 11-15-2005 12:21 PM |
toggle timeline insertion | c-post | Tips & Tricks | 5 | 02-08-2002 12:53 AM |
