Old 07-06-2024, 10:33 PM
NedW NedW is offline
Default Laptop charging uses up processor
Hi all, was just having trouble bouncing down with error message to reduce native plugins. Solved by unplugging laptop charger ??
All playback glitches & bounce problems solved. Currently using pt11 with reason 13 sitala & synth master on dell latitude 5285 with ssl2.
Old 07-06-2024, 11:01 PM
Default Re: Laptop charging uses up processor
Seems weird, but several potential causes to look at, including the CPU not using turbo boost mode when on battery power, and/or the CPU generally slowing down so it also avoid potential overheating/sudden throttling. Hopefully you have the system fully optimized, every last thing done, BIOS settings, etc.. And also have done standard troubleshooting, especially for plugins.
Pro Tools 11 is old stuff. It lacks significant improvements in AAX plugin processing optimization/scaling that Pro Tools gained several years ago. And lacks all the nice freeze/commit workflow that can help offload lots of CPU processing, and lacks disk cache (unless you have 11HD) which can also help avoid CPU errors, etc.
Old 07-06-2024, 11:45 PM
Yeah, all bios & system tunes done (no turbo as advised on read me’s) seems like a hardware issue. Charger was from 12v 100ah batt charged, then through voltage stabiser then stepped up to 24v running usbC 20v. Later I ran charger of high current lithium 48v & no glitches. But still charging seems to massively interfere with processor.
Apple Announce First MacBook Pro Laptop With 8-Core i9 Processor As Part Of Laptop Ra unkJE General Discussion 1 05-23-2019 05:21 PM
Serious MIDI problems on Mac Laptop (i7 processor) Groovacious macOS 0 07-23-2011 12:32 AM
Anyone tried PT8 on a new mini-laptop with Atom processor? Herkimer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 07-09-2009 08:55 AM
Laptop issues with Dual Core Processor, please help!!! andyaynow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 07-26-2007 05:02 PM
Windows Laptop Compatibility - duo core processor smackeroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-07-2007 06:03 AM
