Re: Pro Compressor side chain bug
Also, do you have 'dynamic plug-in processing' enabled? Does it help if you disable that? (my guess is that without dynamic plug-in processing, protools will not deactivate anything when it 'assumes' there is no signal to be expected) Last edited by yoerik roevens; 05-12-2017 at 08:28 AM. |
Placing a blank region/clip on the C track makes no difference. Neither does dynamic plugin processing. The reason I discovered this was by accident. I was printing some stems and the duck bus was deactivated. To my horror the stems were compressing when of course they should have been clean. Not what I wanted!
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2024.10.1 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2024.10.1 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
I believe I have seen the same behavior in Fabfilter's Pro-C2. If you assign a bus as the key input, the compressor will not see the sidechain until that bus is actively engaged in the session i.e. that bus needs to be active on a send or output for the plugin to recognize it. If you just use a random bus from your I/O that isn't used, it won't see the key input.
---------------------------------------------------- MacOS 13.6.9 / Pro Tools Ultimate 2024.6 |
#16
This is what you guys are seeing, right?
https://www.dropbox.com/s/xo3dmpdm5q...31.42.jpg?dl=0 https://www.dropbox.com/s/zc599tlyd4...31.28.jpg?dl=0 https://www.dropbox.com/s/qwlcxufdfr...31.17.jpg?dl=0
#17
This appears correct. My gripe is why the compressor is active when the side chain effectively sees no signal when the trigger bus is inactive.
#18
Gotcha. This scenario makes sense to me, but as said, I don't know if this is intended behavior. Inactive sends feeding the SC bus = "pulled plug" (in lack of a better analogy) = normal compression.
#19
Hear you. As I am a remnant from the days of mixing consoles and patch bays I feel that disabling a bus/send is analogous to yanking out the patch cord that feeds the s/c on the outboard processor!
#20
Hello!
I had the same "issue", and I would like to jump that up because it feels really unnatural to me that when no SC bus are active, then the plug-in get back to the input feed of the plug-in. It's even more strange on fabfilter C-1 because that plug-in has an "IN/EXT" switch.... and even if it is locked to EXT, it behaves as IN if the bus on protools are not active on any track. It took some time to me to understand what was happening as it was for a VoiceOver dubbing session, so the SC and input are almost at the same time. |
Creating a side chain compressor | lownotesinc | Tips & Tricks | 10 | 02-09-2012 02:40 AM |
Is it possible to side-chain an EQ? | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2009 07:00 PM |
Compressor side-chain how to? | porkipine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2008 10:34 AM |
How do I set up a Side Chain | junglelabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-30-2007 11:49 PM |
SIDE CHAIN EQ+COMPRESSOR COMPRESSING VOCALS | mihau | Tips & Tricks | 2 | 10-19-2002 02:17 PM |
