Old 02-07-2001, 07:34 AM
Trash Man Trash Man is offline
Default Deleting unused regions, but the audio files still are in the session\'s folder.......
Do you know what I mean..I go into the session and SELECT UNUSED REGIONS > CLEAR SELECTED> DELETE FILES and so I close the session....When I go into the audio files folder of that session I still see all the old takes (or at least most of them) I usually have to reopen the session and put an exclamation point next to all the used regions, then close the session and drag out all the files w/ no exclamation point...This takes forever and in case you're wondering why it matters to me it's because it takes forever to stuff 80something files rather than 20......
Any help appreciated...
Old 02-07-2001, 02:15 PM
Default Re: Deleting unused regions, but the audio files still are in the session\'s folder.......
someone, anyone????
Old 02-07-2001, 02:38 PM
lwilliam lwilliam is offline
This might be more a Digi question, but I suppose it's possible that when you delete regions (and not the files), PTLE leaves the entire file there that's associated with that region - it won't just delete "part" of the file that contains the unused region.
If you do a "consolidate regions" on a track-by-track basis, then you'll end up with a single region and file per track and you can then get rid of most everything else.
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 02-07-2001, 05:28 PM
Przemek Przemek is offline
If you cut sth from file and then deleted everything, file was removed but not erased, because regions from it were used by that session. Then if you remove those regions, file does not belong to that session and therefore cannot be removed. You can remove everything except whole files at first, or, better, add all soundfiles from audio files folder and _then_ delete everything. Works.
Przemek.
PS - the second idea is not mine
http://imaginatlh.com/91709
Old 02-08-2001, 07:46 AM
DigiTechSupt's Avatar
Trash Man,
-Enable Show Full Pathnames from the Audio Regions menu and take note of all your audio files/regions directory location on your drive(s).
-Perform a consolation of your audio with the Select Unused Regions>Clear Selected>Delete (and not Remove which will only remove the data from the session and not from the drive), command sequence.
-Compare the filenames and locations of the audio left in the session with the audiofiles in the Finder. Are any of the files that were Deleted from the session (not Removed) and still left on your drive(s)?
Brent
Avid Audio Tech Support
Support FAQ
Old 02-08-2001, 12:11 PM
jnash jnash is offline
Digi,
Will 5.1 have any additional features for file/region cleanup ?
What I want to do most of the time (and what I think most people want to do most of the time) is to delete all regions and files that are not being used in the session (i.e. delete all unused takes). No need for individual prompts, no need to remove files that have regions in use... just kill everything that isn't in a playlist.
Currently you have to select all unused regions, then select "delete," then choose "Yes" for every region that can be removed, and "No" for every region that cannot be removed. Wouldn't it be great to get that functionality without all the prompts and (frequent) confusion ? Digi ?
Thanks,
James
[email protected]
Old 02-08-2001, 12:32 PM
Chompers Chompers is offline
If you "option-click" the first "OK" dialog box. then you will bypass the idiotic confimation on each file.
AND..BY THE WAY..
why doesnt pro tools name the sessions audio files after the session name? ie.. " Stairway to heaven's audio files", "Cheezy ballad's audio files"..etc...
Old 02-09-2001, 08:11 AM
Chompers,
The Audio Filenames are generated based on the name of the track (or current enabled playlist).
jnash,
No, Pro Tools 5.1 does not include any additional region/file management commands in the Audio Regions List menu.
Brent
Support FAQ
safely deleting audio folder of unused files oreo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-17-2009 11:46 AM
Deleting unused audio files Beyond The Pale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-15-2006 10:49 AM
Deleting unused audio regions: problem. Dayliner Tips & Tricks 6 01-06-2004 05:18 PM
Deleting unused Audio files/ Question... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-07-2002 03:33 AM
Why doesn't PT look for files in the session's Audio folder first? trombino Pro Tools TDM Systems (Mac) 4 09-14-2001 10:22 AM
