Old 09-27-2010, 10:47 PM
smpkeys smpkeys is offline
Default Onyx or Cocktail?
I've seen some people post about using one of these to keep the mac os running clean. Is one better than the other? And if I do a general "run scripts" on either of these, are the most common things already pre selected, or are there other things that some of you out there like to check?
Thanks!
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Old 09-27-2010, 11:14 PM
TimNielsen TimNielsen is offline
Default Re: Onyx or Cocktail?
They would both do OK. My favorite is actually Main Menu, it has a 'batch' function similar to Cocktails. I used Cocktail for years, and it totally does the trick. The nice thing is you just set up 'Pilot' with your prefs, and it's really easy to run them all at once any time you need.
Old 09-28-2010, 07:25 AM
drenkrom drenkrom is offline
Both those programs, and most others like them on OSX, are really only graphic interfaces for UNIX programs built into the system. You can accomplish all the same tasks in the Terminal. Since there is no difference at all in the actual actions they execute, just go for the one with the interface and automation features you like best.
Old 09-28-2010, 02:03 PM
Thanks everyone for your input!
Tim, I'm trying "Main Menu" now - downloaded the free trial.
When you run "batch tasks" , do you end up selecting most options listed? Or are there ones that you omit? I came from windows so I'm not sure what a lot of these do.
Also, on any of these programs, Do you guys schedule them , or just manually start them at the end of the day at quitting time?
Thanks!
Advices on OS X maintain, cocktail menus.... Aquarius Pro Tools TDM Systems (Mac) 6 03-17-2023 05:16 PM
Using Onyx montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-11-2011 02:30 PM
New version Cocktail software available Park Seward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-20-2007 08:04 PM
cocktail ??? bbob Pro Tools TDM Systems (Mac) 10 03-21-2005 12:33 PM
PT LE 5.01, G3 Beige and 9.1, a nice cocktail? quisco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-03-2001 05:59 AM
