Old 04-24-2004, 02:52 AM
hyrobase75 hyrobase75 is offline
Default Stereo audio files playing in mono
I seem to have a big problem with some of my songs. The songs were imported into ptools and then drug to a stereo track, But after burning to Toast, they're playing in mono. Please Please any help is appreciated.......BASE
Old 04-24-2004, 10:13 AM
qgrm qgrm is offline
Default Re: Stereo audio files playing in mono
need more info. you're sure they were stereo to begin with?
Trogdor - I pine for you
http://www.homestarrunner.com
Old 04-26-2004, 08:37 PM
When creating the session I set up the tracks for stereo because I wanted to experiment with mastering. I took tracks from a cd and imported it to ptools. After the import I went to the audio files region list to the far right and drug the audio from there to the specific stereo tracks. Hey thanks for your reply man................ Base
Old 04-27-2004, 12:26 AM
could it be that your'e bouncing or exporting from PT as mulitple mono (instead of stereo interleaved) and then you wind up burning only one half of the track?
B.
Old 04-27-2004, 04:26 AM
CCash CCash is offline
Or you don't have the track panned L/R before you bounce. Make sure the bounce source is is set to be 1-2 also (in the bounce dialog box).
Old 04-27-2004, 08:01 AM
stereo type stereo type is offline
You haven't given enough information. What are you doing AFTER placing the audio into PT? Are you bouncing to disk, using audiosuite to create new tracks or recording audio onto new tracks via busing? How are you getting the PT audio into Toast? If bouncing you should use the stereo interleved setting. Toast didn't used to see SDII files either........you'll need to use stereo .aif
I believe Toast still only imports stereo files. If the end result of your work in PT isn't a stereo interleaved file, you may be providing Toast either a .L or .R file. Some programs like Waveburner autmatically look for the companion files when seeing .L or .R. Toast doesn't..............or at least didn't used to as of the last version I used.
Help-on how to convert stereo files to mono on 69 tracks dairyman3833 Pro Tools 10 6 10-08-2013 03:42 PM
Stereo Audio Tracks playing back mono rtebel macOS 2 03-25-2012 10:43 AM
convert 2 mono (L and R) files to a stereo mp3 blankpro Pro Tools TDM Systems (Mac) 2 01-10-2010 11:16 AM
Stereo Files in Bin Showing up as 2 Mono Files autopilot Pro Tools TDM Systems (Mac) 2 07-18-2005 10:57 PM
Mbox is playing stereo mix in mono imnotwillie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-05-2004 09:32 PM
