Old 12-04-2024, 01:37 PM
isilrae isilrae is offline
Default Pro Tools Not Starting After Synthmaster Plugin Installation: Seeking Solutions
I've been using Pro Tools Intro for a little over a year. A few days ago, I purchased the Synthmaster Everything Bundle and installed all the plugins. However, after installing the plugins, Pro Tools failed to start. I tried deleting and reinstalling Pro Tools, but that didn’t resolve the issue.
Next, I checked the AAX file locations and deleted the Synthmaster files from Pro Tools’ plugin folder. After deleting and reinstalling Pro Tools again, I attempted to open an old project, but it gave the following errors: "Track was dropped because the maximum number of disk tracks was exceeded" and "Could not complete your request because access violation occurred, unable to read location: 0x0000000000000000."
I completely uninstalled all Synthmaster software and reinstalled Pro Tools once more. Now, Pro Tools works, but I can’t use the Synthmaster plugins. What can I do to resolve this?
Old 12-04-2024, 06:55 PM
junkgear's Avatar
junkgear junkgear is online now
Default Re: Pro Tools Not Starting After Synthmaster Plugin Installation: Seeking Solutions
It sounds like it is more a plugin issue than a Pro Tools issue.
Make sure you downloaded the full plugin installer and not just the upgrade installer. The upgrade installer does not contain all of the needed files to run the plugins and that would most likely cause issues like you are seeing.
You can also try to clear the plugin cache, which will force PT to rescan all of your plugins. Cache files are located in ‘ Users/Shared/Pro Tools/AAXPlugInCache’
Will
System Details
Old 12-05-2024, 04:41 AM
tope d's Avatar
tope d tope d is offline
...same thing I would check
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 12-06-2024, 02:24 PM
Followed your recommendation, but it didn’t work. I also tested SynthMaster with FL Studio and Ableton, and it worked without any issues in both. However, I’m still unable to use SynthMaster with Pro Tools. Additionally, I need to clarify something: I was using Pro Tools Studio, but my subscription expired without my knowledge, so it automatically downgraded to Pro Tools Intro. I’ve since renewed my subscription to test the plugin again.
HTML code is On
Seeking Octaver (and plugin bundle recommendations) SonOfSound AAX Plug-ins 5 01-04-2018 03:53 PM
seeking Windows/Pro Tools installation expert wildplum Windows 2 03-25-2016 08:03 AM
Cannot assign Envelopes in Pro Tools 11 Using Synthmaster 2.6 obsidianforest AAX Plug-ins 0 01-15-2015 09:59 PM
Seeking 2 beta testers for new plugin. WilliamKalfelz AAX Plug-ins 39 07-28-2014 11:05 AM
track/plugin delay, question/solutions? Chompers Pro Tools TDM Systems (Mac) 3 01-16-2002 03:01 AM
