Old 06-18-2013, 12:42 PM
derFunkenstein derFunkenstein is offline
Default Click won't play [SOLVED]
This has got to be the most mundane, n00b thing but all a sudden I can't get the click to play in new projects. I've tried routing it to a submix bus and then that submix out to the Master, and I've tried routing it straight to the Master. I can play back software instruments and I can record/play back audio. But the click, she no worky. I added it via the Track menu -> Create Click Track. I've deleted/re-added it. Everything else is fine. Suggestions?
I'm on 10.3.5 on Mountain Lion 10.8.4. 8GB of RAM, Core i5 CPU, SSD system drive + 1TB audio drive.
Old 06-18-2013, 02:04 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Click won't play
Options > Click (Is selected)
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-18-2013, 02:55 PM
OMG I am such a dingus. That was it. Thanks.
Old 12-11-2015, 06:59 PM
halgalardi halgalardi is offline
lmao just had the same problem and this thread gave me the answer. some things are too simple to figure out
Old 06-17-2019, 04:36 PM
musicmattps musicmattps is offline
Default Re: Click won't play [SOLVED]
Greetings from 2019! This post JUST helped me on this issue!!
Thanks!!
Old 09-23-2021, 05:24 PM
soundartsonline soundartsonline is offline
Default Re: Click won't play [SOLVED] THANK YOU!!!!
Not only did this solve my conundrum as well, but I got a laugh out of this thread!
Old 11-07-2022, 04:36 PM
MoonlightRide MoonlightRide is offline
Still fixing the issue in 2022! Thank you!
Old 09-26-2024, 09:00 PM
CassianoMusicMan CassianoMusicMan is offline
Still fixing the issue in 2024! Thank you!
  • Pro Tools 8 M-Powered
  • AMD Ryzen 5 3600 6-Core Processor
  • Windows 10 Pro
  • 32G RAM
  • 240G SSD / 1T HD - SATA
  • M-Audio Profire2626
  • FireWire PCIEx Texas Instuments - Legacy Driver
  • Nvidia GeForce GTX 1660
Is it possible to play a click without pressing play, and have it in sync.... ALowe macOS 5 06-05-2011 05:24 PM
Click track won't play consistently Camilo Orozco Pro Tools TDM Systems (Mac) 7 09-17-2007 11:02 AM
One click then flashin play cursor? willdavismusic Pro Tools M-Powered (Mac) 2 07-11-2007 01:01 AM
Mouse click changes play button but won't play screaminbytes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-13-2007 11:13 PM
click track play back eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-27-2005 09:49 PM
