ADAT optical in via Lightpipe and i get nothing
I am running a lightpipe from my focusrite isa428 Optical ADAT out into my new 96io optical ADAT in. I cannot seem to get a signal from it. I can see signal on my 428 but no signal when i try to record a track from any of the 8 optical inputs. I have set up my i/o setting to have the optical be 9-16 (basically the default settings). What else do I need to do? I can't figure it out. Someonw else had said something in another post about session setup? What is the deal with that?
Thanks in advance |
Re: ADAT optical in via Lightpipe and i get nothin
Do you have lightpipe connected the other direction as well? I think your 428 needs to see clock information from the Digi unit for the connection to be complete.
I just did this using and ADAT as an A/D converter and I had to have both the in and out connected..... |
428 only has ouput. and i am using clock sync. I was using it with my ADAT bridge on my mixplua system and did not have a problem. So, i am thinkin it is a software setup issue, but i cannot figure it out.
Re: ADAT optical in via Lightpipe and i get nothing
In the main Hardware Setup window you should have inputs 9-10 to 15-16 set to ADAT 1-2 etc. not Optical 1-2(ADAT), and on the Digital window, have ADAT 1-8 selected on the Input Format. Hopefully that helps. That is how I have my Presonus Digimax setup to my 192. Not sure if the 96i/o would be different.
Optical lightpipe help please | brickroadstudio | Pro Tools HDX & HD Native Systems (Mac) | 0 | 04-15-2011 11:42 PM |
Clock Issue on 192 i/o Optical [ADAT] Not Optical [Encl] | Willard | Pro Tools TDM Systems (Mac) | 1 | 10-10-2007 01:23 PM |
Lost optical / ADAT / lightpipe I/O ! | pklem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-15-2004 03:22 PM |
whats the difference between adat optical and spdif optical? | Vegadark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-07-2002 07:42 PM |
ADAT bridge: same as ADAT lightpipe cable? | Jim S | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-16-2001 07:37 AM |
