I'm running LE on a G4 and having dupliaction problems. Every time I duplicate in etiher bars and beats, or minutes and seconds modes, the regions wont snap to the bar. So eventually everything starts to go a bit out of time. I've tried using the grabber, bar and also tabbing the region. Nothing seems to make a difference. I have worked in bars and beats mode on a TDM system and just simply selected the region with the bar and dupicated 'til my hearts content... no problems whatsoever, but now?
This is very frustrating and is certainly stalling the writing process. Any ideas? |
did you change the snap grid to 1 bar? It sound like your grid if set to something else. It is located in the top right hand corner of the edit screen.
citi |
I assume you are in grid mode, right?
Yeah tried the one bar thing. No difference. and yes I'm in grid mode. I'm primarily working with programmed beats and loops etc. so snapping to a grid is crucial.
thanks. |
Check out your PTLE manual p154, there's a paragraph about "Sample-Rounding and Edit Operations". This is what you are looking for.
Sorry when I said the Bar, I meant the Selector. I read page 154 but I always use the Selector to select a region before duplicating. This doesn't make a difference, it still wont snap to the bar.
Thanks again. Andrew |
Try the same thing using Repeat (apple+R), see if it works...
Some music?... http://tmweb.free.fr |
does your region that you are selecting start EXACTLY at the beginning of a bar and end EXACTLY at the end of a bar?
Duplicating regions (the way I experience it) takes the region you have selected and places a copy of it immediately after that region. If the original region does not end exactly at the bar, then the duplicated region won't start exactly at the bar. And the more duplications you make, the more drift away from the bar there will be. Does that help any? hyp0static |
![]() Quote:
dk
http://homepage.mac.com/dkrausz |
Thanks for all your replys.
Yes the region starts and ends at the end of the bar. I can see this when I zoom in as far as possible using the magnifying glass. So far the most successful is the repeat option. This seems to be solving the problem, although I still can't understand why I'm having trouble duplicating. Keen to hear more of your thoughts though. Andrew |
Off grid when duplicating samples or regions | critza | macOS | 2 | 10-27-2012 12:03 PM |
Duplicating regions is weird? | timmy4402 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-10-2009 11:03 PM |
duplicating midi/inst regions auto-joins regions? | WestphalMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-10-2009 10:44 PM |
Duplicating/ copying regions | Joe H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-09-2006 04:38 PM |
New Bug in 5.1.1? (duplicating regions) | Mt.Everest | Pro Tools TDM Systems (Mac) | 16 | 11-05-2001 12:00 AM |
