Old 05-06-2008, 05:04 AM
toneski toneski is offline
Default G5 Dual 2.7GHZ - Sata I or Sata II Drive setting ?
I have a G5 Dual 2.7GHZ Powermac and I have just ordered two Seagate 7200.11 500GB drives to fit internally. They can run as Sata I or Sata II drives depending on jumper positions. Should I set the drives to run in th Sata I mode or Sata II mode? Any help would be very much appreciated. Very many thanks,
Regards
Tony
Hackintosh Quadcore i7 3.4GHZ; OS X 10.8.4; HD4 PT version 10.3.8
Old 05-06-2008, 10:42 AM
Default Re: G5 Dual 2.7GHZ - Sata I or Sata II Drive setting ?
Bump!
Regards
Tony
Bump!
Regards
Tony
Old 05-06-2008, 11:55 AM
TCDet TCDet is offline
150 (Sata I) not 300 (Internals).
Unless you add a Sata II card for performance.
BTW: System profiler gives the bus speed!
Let us know how the new drives work out.
tc
Old 05-06-2008, 12:18 PM
Many thanks for the advice TCDet, I will leave the drives in the Sata I setting. I will let you know how they get on, other DUC contributors are already using these drives I think and they seem to run cool and fast. Once again many thanks,
Regards
Tony
Best second internal hard drive in G5 Dual 2,7GHz Labyrinth Services Pro Tools TDM Systems (Mac) 5 08-31-2006 05:37 AM
Which SATA 2 drive for G5 Dual Core DaveSB Pro Tools TDM Systems (Mac) 4 07-24-2006 03:42 PM
Do SATA Controllers/ PCI Cards/ SATA Drives work.. Jason Robo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-14-2005 07:23 PM
Onboard SATA + PCI SATA + Protools LE = bootcrash? insolace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-10-2005 11:06 AM
Setting up a SATA drive - how? Voideco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-14-2004 11:59 AM
