Equalizer APO / PT DAW
Hello,
does anyone use / run Equalizer APO while also running PT? I'm not sure if I should be more worried about it running my RME sound-card or the DAW. Anyone have any experience running these two applications simultaneously. Many thanks! |
Re: Equalizer APO / PT DAW
Just to update my experience if anyone else would be looking for this info.
I did install and use Equalizer APO on my system. I've tried many times to use it while playing back PT10 and it would not allow output modifications while PT was running to the audio from PT. Maybe I don't have something configured correctly in PT. The computer would seem stable for both PT and EQAPO to be running but unable to affect change to designated outputs while PT is running. |
I got the same problem but somehow I find a way to solve it without using my interface(Focusrite 2i2). To use Equaziler APO and pro tools together you need to send the pro tools audio out to banana voicemeter. so it will look like this:
pro tool audio - banana voicemeter - EQ APO - speaker. I still can not use EQ APO with my interface yet together with PT . Hope this will help you and give you some idea. |
IR-1 as an Equalizer | Mark Reis | Tips & Tricks | 7 | 02-02-2006 08:50 AM |
What is "Q" in AudioSuite's 4-Band Equalizer? | beau johnson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-12-2005 05:02 PM |
Avedis E15 Equalizer | tzujan | Pro Tools TDM Systems (Mac) | 0 | 09-03-2004 10:05 PM |
GRM TOOLS EQUALIZER DELAY | derF | Pro Tools TDM Systems (Mac) | 4 | 04-02-2003 11:22 PM |
dynamic equalizer | Martijn Stienstra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-29-2002 03:50 AM |
