Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 06-03-2023, 05:42 PM
kingtone kingtone is offline
Default MTRX and MTRX STUDIO together?
I was planning on adding another MTRX ST and HDX card to my system, but can possibly get a good deal on a MTRX and HDX.
Does anyone know if you can have a mixture of MTRX ST and MTRX in the one system without problems?
MTRX ST off HDX#1 and MTRX off HDX#2
(Obviously monitoring only off one of the units. )
Apologies if this has been asked/answered… my searches didn’t come up with any solid answers
Old 06-04-2023, 03:16 PM
BScout BScout is offline
Default Re: MTRX and MTRX STUDIO together?
Yes. You can (have done it)
They show up as different devices in DADman (they are, of course, self-contained -- there isn't any patching between the two unless you run cables between them like Dante/Dante Controller patching)
Pro Tools Ult 2023.9, HDX 3, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, FireHD x 2, Dock, iPad Mac Mini 14,12, 12 core, macOS 13.6RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 06-04-2023, 03:19 PM
Perfect. Thanks BScout!
That’s exactly how I intend to use/patch.
Old 06-04-2023, 09:10 PM
Also, an FYI, the MTRX Studio converters and the MTRX don't have the exact same delay times (it's close but not exactly the same.) Just a warning if you plan to do any parallel compression/parallel signals to make sure direct in signal and processed signal are on the same unit (if a signal source is being patched elsewhere like on a patchbay or mastering router before entering the DAW/converters)
Old 06-05-2023, 03:32 PM
Good reminder.
I had actually noticed that in my research.
Appreciate the reminder tho!
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX MTRX Studio Forum Section? off the wall Pro Tools | MTRX & MTRX Studio 2 05-08-2022 03:20 PM
MTRX Sources - >Trinnov MC16 Dante ->MTRX Out routing ??s Jeff Schmidt Pro Tools | MTRX & MTRX Studio 4 03-18-2022 02:21 PM
MTRX Studio LFE went bye-bye remainanon Pro Tools | MTRX & MTRX Studio 4 02-20-2022 10:41 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
