Metric Halo + DSP and 003
is it possible to use the 2882 with my 00 so that i can have the extra 8 ports and use the DSP function of it? if so am i right in just saying daisy chain the 2 and use ADAT to connect the 2?
3.2 dual quad 4gb mac pro 10.5.6, logic 8.02/ PT8 003 factory through RM2's |
Re: Metric Halo + DSP and 003
I'm a little unclear about the full functionality of the 2882 in "Standalone Mode"
Pro Tools will recognize the MHLABS unit, as Adat 1-8 in the 003 i/o You will NOT however be able to access any DSP power, from Inside pro-Tools. At Best, this would be an 8ch Analog to Adat converter for you. I'd contact Metric Halo (The always answer their phones, and are quite helpful) about using the unit in Standalone mode, to convert 8 Analog in's to Adat out.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
thank you so much for your feed back, i will speak to them directly in this matter. using the dsp is a main priority though, hope i can use the plugs
Thanks G
MacBook Pro M2 Max / Pro Tools 2024.3.1 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos / |
PT9 and Metric Halo ULN2 | Bill Way | Pro Tools 9 | 2 | 04-11-2011 07:05 AM |
Metric Halo 2882 anyone ? | kite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-19-2006 11:03 AM |
DSP of Metric Halo ULN-2 | mcician | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-07-2004 11:56 PM |
Anyone at NAMM see Metric Halo and CS for OS X? | chrispnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-17-2004 09:30 AM |
Metric Halo ULN2 | tele_player | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-19-2003 05:03 AM |
