Dual screen setup help please.
I've connected a second monitor to the output on my graphics card, HD 2600, but can't get a picture.
Do i need to set anything up beforehand? The second monitor is a different resolution, is this the problem? |
Re: Dual screen setup help please.
The output of the card has to be configured. Sometimes simply rebooting with the both monitors attached will do it if the card is smart enough to see that it has two connections, otherwise go to the desktop, R-Click and select Properties - the select Settings and you should see the configuration options.
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox 09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox 10/31/2009 - Win 7 64Bit MBox /PT not supported under Win7 - I didn't leave PT, PT left me! 11/30/2009 - MBox, REAPER http://www.jazzmandan.com |
Tried the reboot first but nothing, second screen remains on standby.
Right-clicked into display properties/settings, checked the "Extend my windows desktop" box then apply but still nothing. Reset again but second screen remains on standby and display properties/settings has been reset. Any ideas? |
It sounds like you are having problems just getting the second screen working. Have you followed the dual-screen instructions for your graphics card? Do you have the right drivers for your graphics card?
You might want to check the ATI forums for help getting dual screens working for your specific card. Before we can help you with Pro Tools on two screens, you need to actually have the computer working on two screens.
Your Video card must be designed to handle two monitors, not any card can do this. Some cards my have dual outputs but these are just analog and digital and can not be used independently. If your card do handle dual monitors then the "...display properties/settings" is the place to configure it. Do you know your card can do this??
Yes, it can control 2 monitors in display properties/settings i can click on "1" or "2" and select resolution, bit depth etc.
I'll try ATI forums. |
Discovered the problem, it's the new DVI to VGA converter - it has more pins than the 1 i'm using on my primary screen so somehow isn't compatible.
Dual screen Macbook Pro setup | Ruthven | Post - Surround - Video | 8 | 02-24-2011 06:25 AM |
PT 8 : Dual screen bug ? | yoann | Pro Tools TDM Systems (Mac) | 0 | 12-06-2010 08:03 AM |
dual screen use | bo-jingles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-14-2006 08:07 PM |
Dual screen ... | Caballero | Pro Tools M-Powered (Win) | 5 | 06-15-2006 09:11 PM |
Dual Screen setup | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-06-2006 03:15 PM |
