Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-04-2014, 09:23 PM
rjr303 rjr303 is offline
Default IK Total Studio 3 Installation Error in PT10
I have installed IK Multimedia Total Studio 3. For every selection I click on, I get an error "the plugin could not be made active because a DAE error was encountered. DAE error -7401 was encountered".
IK was installed under an administrator account and installed with 'run as administrator'.
Pro Tools 10.3.8 on Windows 7 Pro 64-bit
Saffire Pro 40 FireWire Audio Interface
Intel i7 4 core, 16 gb ram
Old 04-04-2014, 10:56 PM
Default Re: IK Total Studio 3 Installation Error in PT10
I was finally able to resolve the problem. This plugin package from IK is probably the worst I've ever worked with. The key to getting it to work is to do everything as administrator.
- for every installation disk, right click and 'run as administrator'
- you must launch pro tools with right click and 'run as administrator' every time you run it. Otherwise, you get the DAE errors for every instrument selected.
Once you successfully launch an instrument as an INSERT, you must set the PREFS. The default folder location for instrument sounds related to the selected INSERT is not the correct folder. You must browse for the correct folder and save it as the new PREF. After several hours, I finally got it all working.
upgrade from LE to PT10/11 - Installation Confusion Ticker macOS 2 08-26-2013 11:16 PM
Co-installation PT10-11 : cool but... lanstrad Pro Tools 10 4 06-22-2013 10:11 PM
PT10 Error opening installation log file elovaarar Pro Tools HDX & HD Native Systems (Win) 1 11-19-2012 06:42 PM
DAE Error (-9073) = Total Aggravation! Voice Crafters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-07-2012 06:07 PM
PT10 Installation David Lang Windows 6 10-28-2011 10:08 AM
