Digimax Setup Help pops and clicks
I have a 001 and Digimax using 6.1.1 and I can't set up the Digimax properly. In Hardware setup, I have the clock set to Optical, in Optical Format I have it set to Adat, in Sample rate, 44.1khz. The Digimax is set to 44.1 the external clock is set to off. What am I doing wrong please?
Re: Digimax Setup Help pops and clicks
The clock must be set to ADAT optical.. and not Internal. Open the session setup window (Ctrl+2) to verify that the clock is not on internal. When using a digital input, Pro Tools must share the same clock as the source device.
Rail
Umm Yes it already is set to Adat Optical
You want it to be set so RCA = SPDIF/Optical = ADAT and the clock set to ADAT.. if this is set right and you still get pops make sure that your external device is set to Internal.. and that you have good quality cables and connections. Make sure that your Pro Tools sample rate matches the sample rate of your external clock source.
Rail
Thanks Rail, it was a connection problem, I hadn't pushed the cable into the Digimax properly...doh!
Pops and Clicks, DIGI001, Digimax ADAT interface | LenNJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-16-2006 11:10 AM |
digimax (adat) clicks and pops | pioneerptw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-23-2005 07:00 AM |
digimax (adat) clicks and pops | pioneerptw | Pro Tools TDM Systems (Mac) | 2 | 09-23-2005 04:53 AM |
odd pops/clicks digimax lt and digi-002 | sblair | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-07-2005 06:04 PM |
Digimax making clicks and pops. | tmat1075 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-09-2002 12:38 AM |
