Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-26-2007, 09:16 PM
insoundrecords insoundrecords is offline
Default What is a good external CD burner to use with pro tools?
I heard that the bounce to disk programing was faulty and it's better to burn my songs onto CD through an external CD burner. I just wanted to know if there were any perticular models that work better with pro tools than others. Thanks for the help.
Old 04-27-2007, 08:29 AM
hemloc hemloc is offline
Default Re: What is a good external CD burner to use with pro tools?
Old 04-27-2007, 09:16 AM
ChaplainPC ChaplainPC is offline
Everyone has their opinion. BTD has gotten better. Try it for yourself. Many RTD. They record their mix back a stereo audio track within the session.
Pete
The Upper Room
Old 04-27-2007, 01:56 PM
Kryst Kryst is offline
Just to be sure... You're not trying to Burn to a CD through Pro Tools, are you? Unless that's a new feature I've missed out on noticing, I don't think an internal or external CD burner will change anything.
Kryst
Old 04-28-2007, 12:45 AM
I guess the bounce to disk programing is about 10 years old and faulty, and nobody wants to fix it since its a really long process. So I was told to play a song out of the monitor outputs or 2 of the outputs into an external cd burner to make a cd. The bounce to disk doesn't capture your mix accurately so it doesn't sound the same. But some external burners are better than others and some probably work better with pro tools.
Old 04-28-2007, 12:20 PM
Oh, I think I misunderstood the external burner you were talking about. Sounds to me as if you're talking about one that burns as the music's playing into it. I was just thinking of an external computer drive
Kryst
Old 04-28-2007, 12:21 PM
Kryst
Old 04-28-2007, 02:17 PM
jre3132 jre3132 is offline
just because the bounce to disk doesn't sound great, doesn't mean you have to play to an external burner. They may have meant to use the Record to Track and export technique. Once you get the file out of Pro Tools, I don't think it matters if you have an external or internal burner.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 04-29-2007, 06:45 AM
lemix's Avatar
lemix lemix is offline
True that..
He was most likely asking about "CD Recorders"
these ones >>
andrew
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
A good CD burner and 2-ch AD/DA converter? Naagzh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-23-2004 06:53 PM
Good Deal on DVD Burner Sugarnutz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-14-2003 03:49 AM
Which is a good Mac cdrw burner ? Marc Cooreman Pro Tools TDM Systems (Mac) 28 12-23-2001 12:26 AM
Help Finding Good CD Burner Buy... tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-10-2000 06:04 PM
Can someone recomend a good C.D burner? jag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 03-11-2000 07:23 AM
