#21
Re: I need more memory access for VI's
Ermm ... well, actually Reaper apparently will not work as a slave under Protools 9 on the Mac. That's my whole problem.
If anyone has any suggestions for a solution, they are appreciated. Best Harry. |
#22
maybe describe the issues you are having with it...
Lincoln Mitchell www.studiofifty.net Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue |
#23
Another option you should check out is Plogue Bidule...it works really well with PT9. It is a program that allows you to run a multitude of VI's and reads both Vst and Au plugs. So you could run Garritan, Kontakt and any other other VI's in Plogue either as rewire or standalone mode into PT and it is available in 32 or 64 bit versions so you are only limited by the amount of Ram in your system. There are a couple of good videos on youtube if you search for it. Hope this helps.
#24
2Sonic and Lincol1, thank you very much for your replies.
Amazingly - this evening - I had a breakthrough ... I discovered that I could get REAPER to show up as an INSTRUMENT INSERT when I put the Reaper App and files in the same folder as the PT9 session file. Wow. Mine eyes have seen the glory. I have Reaper as a stereo insert. Now I have to work out how to get my keyboard input to play the damn thing. So there you go. Thanks for the replies and, if you have any further thoughts, please post them. Many thanks, Harry. |
#25
#26
As for other suggestions, there are posts here and on the reaper forum ad nauseum, so whatever your working on dig around, you'll find it. Shane at one point posted some session templates even. If you are still stuck pm me and I'll walk you though it.
#27
I know this is Max OS X forum but I thought maybe someone could help me here :) Is the Memory Server in Kontakt4 available for win 7 ? and what is Plogue Bidule? Thanks |
How do you not get access memory violation errors? | Dan-Jay | Pro Tools M-Powered (Win) | 25 | 01-23-2011 07:41 PM |
Access violations, Runtime errors, not enough memory etc | Seagate Studio | Pro Tools TDM Systems (Win) | 4 | 05-19-2010 03:08 AM |
50 Spectrasonics VI's, 50 NI VI's and 50 structure all in one pro tools session | crizdee | Pro Tools TDM Systems (Mac) | 11 | 04-03-2010 09:03 AM |
7401, access violation, memory problems | jarred Decker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-22-2009 11:54 AM |
Not enough Memory to access audio drive? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-12-2009 11:58 AM |
