Old 04-27-2022, 05:02 PM
K Roche's Avatar
K Roche K Roche is offline
Default Does the new 2022.4 update fix the loosing I/O setting bug
So a good while back (6 or 8 months or more )I reported a bug where on Catalina 10.15.7 with PT Ultimate 2021.12 in the Carbon Hardware window I/O settings If you closed a session and launched a new session with a different sample rate like say from 44.1 to 96 the Carbon I/O would default the settings and no sound would play And resetting the HW settings would not work because as soon as switched from the HW page back to the session it would default again .. I am just wondering if Anybody knows if this finally got fixed in this new release , before I upgrade ?????????????.
I had opened a support ticket (as suggested by Mark Corbin ) and with some back and forth screen shots and video with Avid, they were able to reproduce the issue and said they were working on it...... but I never heard back
System :
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1
Enjoy the Journey
.... Kev...
Old 04-28-2022, 06:20 AM
K Roche's Avatar
Default Re: Does the new 20221.4 update fix the loosing I/O setting bug
Bump so hopefully somebody from Avid can answer this
System :
Enjoy the Journey
.... Kev...
Old 04-28-2022, 10:21 AM
junkgear's Avatar
junkgear junkgear is online now
Check out the 2022.4 Release Notes, specifically the carbon section. There seems to be a fix for what you are talking about.
  • HP and Line Outs are now recalled correctly when switching between sessions with different sample rates (PT-280415)
Will
System Details
Old 04-28-2022, 01:15 PM
K Roche's Avatar
Thanks for the reply I had read that was not sure if that was actually it.. Because the In the Hardware Setup box ,,,the Monitors "Main" tab the Main( MON L-R ) would uncheck itself and in the Line I/O tab the Line an Bypass would go to default and the Line Out Reference Level would switch from my setting (all at +4. dBu) back to -10 dBu so if that is indeed what (HP and Line Outs are now recalled correctly when switching between sessions with different sample rates (PT-280415) is......then that is great ,,, guess I will update and see , thanks again
System :
Enjoy the Journey
.... Kev...
Old 04-28-2022, 03:23 PM
MCorbin's Avatar
MCorbin MCorbin is offline
Yep, that was it!!! Thanks for the patience Kevin!
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 04-30-2022, 12:30 AM
LFO LFO is offline
Default Re: Does the new 2022.4 update fix the loosing I/O setting bug
Ahhh!!! Glad it's solved at last, still on 2021.7 because of this bug. Thanks.
Old 04-30-2022, 01:46 PM
K Roche's Avatar
Have not tried it on main system (below) on Catalina 10.15.7 and Ultimate 2021.12. But I do have it set up on an external drive with Monterey OS (opening and playing a number of old sessions of mixed sample rates and so far no issues )
System :
Enjoy the Journey
.... Kev...
Old 05-01-2022, 02:56 AM
LFO LFO is offline
Thanks for reporting this
loosing I/O's when I use a D24 on a MIX system Chris Watkins Pro Tools TDM Systems (Win) 5 12-19-2007 12:28 PM
Loosing TEMPLATE setting when "importing audio" KJVMBird 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-26-2007 09:18 PM
EQ3 loosing presets... FredrikThomander Pro Tools TDM Systems (Mac) 1 03-29-2007 01:28 PM
Keep loosing connection with my 002 sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2005 05:29 AM
Loosing your SFX... mark_corbin Post - Surround - Video 10 03-23-2003 09:52 PM
