Old 01-03-2009, 01:24 PM
erant1 erant1 is offline
Default Question Regarding Outputs
Periodically I do cover versions of songs, and I begin by importing the "original" into PT to use as a reference. Once I am near completion of my own version, I've of course inserted numerous compressors, EQ's etc. on the Master Fader. At that point, in order to make a comparison between the original version and my own, I have to individually bypass each plug-in on the Master Fader in order to hear the original version without the additional processing. I know I can't have two Master Faders with the same output (one with processing and one without), as PT won't allow this.
I'd appreciate any suggestions about an easy way to toggle back and forth.
Thanks!
Old 01-03-2009, 01:32 PM
Drew Mazurek's Avatar
Default Re: Question Regarding Outputs
Instead of assigning all your tracks directly to the output 1-2, use a buss as a "stereo buss" and assign that to output 1-2. This allows you to import a track and assign it directly to the "mains" and it won't have your plugs on it. This has the added benefit of giving you pre fader inserts on the "stereo buss" which master faders do not have.
Drew
www.drewmazurek.com
Old 01-03-2009, 02:07 PM
BaileyBass BaileyBass is offline
Thanks!
If you happen to have some sort of Monitor Controller ( Central station, Avocet...) assign a different output to the "original" and input that into one of the sources. You can then toggle very easily. Also, if you have a Control 24.. the "pro tools sources" selector works great for this.
Dmazureks bussing technique is both effective and practical, whether for this specific function or many, many more. I don't know any "top shelf" mixers who do not employ this. good luck.. SB
Old 01-03-2009, 03:33 PM
Thanks, gentlemen. Both suggestions work and are greatly appreciated.
Question about OMNI outputs IO Composer Pro Tools TDM Systems (Mac) 0 12-15-2011 11:00 AM
ProjectMix I/O question about outputs 3 and 4... indiecodemonkey Pro Tools M-Powered (Mac) 3 09-29-2007 01:23 AM
Analog outputs -question lumpo ICON & C|24 1 01-29-2002 12:44 AM
outputs question? Slovenec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-29-2001 11:05 AM
mix outputs question JKD99 Pro Tools TDM Systems (Mac) 2 07-28-2000 12:07 AM
