Old 03-19-2023, 09:34 PM
clarinetdelune clarinetdelune is offline
Default VST/VI Stops Playing
I'm having a recurring issue, most notably with Omnisphere, but also with Kontakt and Diva, where MIDI is being passed into PT (Midi meter registers with every key pressed), but the Instrument won't receive or process the signal. Sometimes it will start working again if I inactivate and reactivate the plugin, but most of the time, I have to reboot PT altogether.
Changing audio buffer does not work. Instrument is correctly routed in the "instrument" tab.
I have updated all of the instruments, updated firmware on my interface, etc.
Novation Impulse is plugged directly into Intel Mac Mini via USB.
Running Pro Tools Studio 2022.12.0
Intel Mac Mini OS 12.6.3
Old 03-20-2023, 12:13 AM
flandybob flandybob is offline
Default Re: VST/VI Stops Playing
In the mixer, did you check the «*instrument*» on top (that’s something you should be able to show / hide same as inserts or sends).
I have a similar recurring issue where PT loses the assignment for no obvious reason. I’ll try to post a screenshot a bit later
MacBook Pro 14" M1 Pro 10 core 16gb/1tb
Pro Tools Studio 2022.7
Apollo "silverface" thunderbolt 3 / Apollo Twin mkII
Old 03-20-2023, 02:07 AM
This is what I mean. Sometimes it randomly goes to "none", not sure if it's an error on my side or a bug
Old 03-20-2023, 05:05 AM
saqibhassan saqibhassan is offline
I have found that instrument-tracks behave better when they have an input assigned.
Old 03-20-2023, 09:51 AM
Not having this issue on my end. All instrument assignments/inputs stay active and consistent, but the plugin will stop processing the midi into audio.
Old 03-20-2023, 03:07 PM
ChrisL ChrisL is offline
i have this exact same issue, and restarting protools is the only solution I have found so far. Really frustrating when you have clients in the room
Old 03-21-2023, 06:38 AM
Carl Lie Carl Lie is offline
I have the same issue. Actually two versions:
1) VI routing drops and needs to be re routed
2) VI sounds drops (routing fine) usually changing my buffer size fixes it.
Another PT silly thing that should not be happening in the highest price DAW available.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 03-21-2023, 06:50 PM
trevvahhh trevvahhh is offline
I have both of these issues as well, the instrument routing changing to "none" has been an issue for years. sometimes instead of none it changes to an instrument on a different track (i.e. drum midi playing through a piano upon reopening session). maddening
but also have the issue where it's correctly routed but the VI just stops working and usually inactivate/reactivate the inst plugin corrects it. but sometimes needs PT restart
OSX 12.6 PT 2022.10
2022.12 had more issues here with midi instrument glitching on bounce
Old 03-21-2023, 11:16 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
OSX 12.6 PT 2022.10
I also have these routing issues occasionally. Restarting PT usually solves it, but many times I'll have to reassign instruments. It can be annoying especially if you have a template that should save time and not require any more routing. It usually happens with just one or two instruments. Fortunately, it's not frequent.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 03-22-2023, 02:40 AM
Audiofarm Audiofarm is offline
I have this issue after a cpu overload message. Not the one with instrument assignment to none but it just stops playing so I have to deactivate/activate the VI..
AUX Buss stops playing Intransit Pro Tools 11 2 05-28-2014 02:29 PM
DV stops playing via canopus MESH@ZU Pro Tools TDM Systems (Mac) 8 09-20-2007 08:18 AM
iTunes stops playing Sunzate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-06-2006 08:26 PM
m-box sound stops playing S.p.Z 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-03-2005 08:27 AM
G4 AMIII stops playing joepopp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-19-2002 01:18 PM
