Ok this is crazy. any help would be appreciated.
just trying to have LESS plugs in my Plugin list. I moved the "InTune" plugin to UNUSED plugins folder as i will never use it yet each time i relaunch PT, that dang plugin REAPPEARS in the PLUGINS FOLDER? it seems to only happen to AVID stock Plugins, not any 3rd party plugs. what is happening? anyone know anything or how to fix this? Monterey 12.3/PT 2021.12.0 Ultimate |
Oh discussed on DUC many hundreds of times. This is normal behavior, all standard plugins are built into the Pro Tools application bundle and if missing from the plugin folder are copied there when Pro Tools starts up.
You are probably best off just leaving this as is. |
thank you!
at least im not going insane obviously they should fix this :) |
Easy!
Right click on the Pro Tools app in Finder and select "Show Package Contents". Then navigate to "Contents"->"Plugins". These are the plugins that Pro Tools re-installs automatically every time it launches. Simply remove the plugins you don't want (or create a new folder somewhere for unused system plugins and drag them there for safe keeping). I remove most of Avid's stock plugins this way, as I do not use them; Less clutter in the plugins menu and Pro Tools even loads a little faster too! Yay! |
fantastic thank you!
Unused plugin folder???? | rdpar | Pro Tools 2018 | 2 | 04-23-2019 01:43 PM |
Unused Plugins Folder | dougdude9 | Windows | 4 | 03-19-2017 05:47 AM |
unused plugin folder location | orvillej | RTAS & TDM Plug-ins | 2 | 06-28-2013 09:15 PM |
files in unused plugins folder | seansolar1234 | Windows | 0 | 01-11-2012 07:14 PM |
Unused Plugin folder and Moogerfooger auth. | danonbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-28-2010 10:52 AM |
