Old 03-30-2003, 02:12 PM
jcoker jcoker is offline
Default DIGI 001, no Ch 1-2 input in Hardware Setup dialog!?
Subject says it all. I just bought a DIGI 001. I'm trying to configure the Hardware Setup. When I open the Hardware Setup dialog box there is no option for setting the Ch 1-2 Input for Channel 1-2 Anolog or S/PDIF. As a consequence, PTLE (5.3.1) is defualting to S/PDIF for new track (1-2) Output, i.e., I have no option to select Analog 1-2 (Stereo) or (Mono). Anyone ever seen this? Thanks.
Old 03-30-2003, 03:07 PM
Greg M Greg M is offline
Default Re: DIGI 001, no Ch 1-2 input in Hardware Setup dialog!?
While in a PT session, go into setup>I/O setup and click on the input tab. Is input 1 and 2 set up for analog on the Digi?
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 .
Old 03-30-2003, 05:37 PM
Greg
<font size="2" face="Verdana, Arial">Thanks for the reply. Yes, 1 & 2 are set up for analog there. I guess as long as I can control it from there, I'm ok? Thanks.
Old 03-30-2003, 06:09 PM
Stone Knife Stone Knife is offline
In PT. Setups> Hardware Setup you should only see 3-4 5-6 7-8 because those are analog inputs without the front-panel faders; but you for sure should see Analog 1 Analog 2 when you click the input button on an individual channel and look under "Interface".
(Make sure you have Display> 'Mix (or Edit) Window Shows> I/O view' selected).
If you don't see it, go into Setups> I/O Setup and click the input tab. If you don't see "Mic/Line 1-2" at the top there, then go to the lower right and click the DEFAULT tab then OK. That will reset the labels for the I/O matrix.
Old 03-30-2003, 06:40 PM
Originally posted by Stone Knife:
In PT. Setups> Hardware Setup you should only see 3-4 5-6 7-8 because those are analog inputs;
Ok. I do see 3-4 5-6 7-8. When I had my Mbox and when I looked in the Digi 001 manual I saw the Ch 1-2 Input fields for selecting Analog vs S/PDIF. I just don't understand why I'm not seeing that field option in this install of PTLE with this new Digi 001. Oh well...
I do.
Make sure you have Display> 'Mix or Edit Window Shows> I/O view' selected.
Thanks for the reply and the above info. Stone Knife.
Old 03-30-2003, 07:12 PM
Sounds like you're good to go! [img]images/icons/wink.gif[/img]
Old 03-30-2003, 10:15 PM
bassbuddy bassbuddy is offline
This might be a given....but in Setups menu, when you pop on Hardware, does the Sync option have internal or optical selected?
If you are not using ADAT or any lightpipe , then internal should be selected. Once this happened to me...i lost analog 1 &2 because i had optical selected, but now i have optical selected, and both ADAT and analog inputs are showing up in my I/O...go figure that one out. [img]images/icons/smile.gif[/img]
kenny
my webpage
Old 03-31-2003, 06:45 AM
kenny
<font size="2" face="Verdana, Arial">Thanks...I'll check this out when I get home tonight. I can't remember if I did anything with the Synch option.
Old 03-31-2003, 05:53 PM
Originally posted by jcoker:
<blockquote><font size="1" face="Verdana, Arial">quote:<hr /><font size="2" face="Verdana, Arial">Originally posted by bassbuddy:
kenny
<font size="2" face="Verdana, Arial">Thanks...I'll check this out when I get home tonight. I can't remember if I did anything with the Synch option. <hr /></blockquote><font size="2" face="Verdana, Arial">Hmmm...looks like PTLE on XP is different from MAC in the menu's arena. I do have internal selected in an area called 'clock' which appears to be equivalent to synch, but I wouldn't bet on it bc I'm new to Pro Tools [img]images/icons/smile.gif[/img] I think I'm ok for now...I just hope not having the option to select Analog or S/PDIF in the Hardware Setup menu isn't going to bite me later. I don't think it will since I can get to it from the Setups; I/O Setup menu too.
Hardware Setup Window Dialog Missing QuickPuppy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-01-2013 08:55 AM
What??? MBox3, 8.05 No Hardware Setup Dialog Box!! Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-01-2011 02:30 AM
hardware setup dialog is empty on digi 002 factory bigboi78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-11-2007 05:31 PM
Can't access Hardware Setup Dialog??? Jepse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-18-2005 10:54 AM
Strange problem in Hardware Setup dialog tld Pro Tools TDM Systems (Mac) 0 08-13-2000 09:07 AM
