Old 12-01-2021, 12:45 PM
globaleric globaleric is offline
Default S1 Ethernet Connection Speed
I took the plunge and finally got my new S1 yesterday. While everything else seems to work just fine so far, I've stumbled across the following while checking the home network configuration of my Fritz!Box home router:
All Ethernet ports of the router are configured to support 1 Gbit connections.
- My Mac mini connects to it with 1 Gbit/s, as expected
- My older Euphonix MC Transport connects to it with 100 Mbit/s, as expected given its venerable age
- My iPad 2020 running Avid Control connects via 5 GHz WLAN with 866 MBit/s, as expected
- However my S1 connects to it only with 100 Mbit/s, NOT as expected since the official S1 technical specifications are mentioning a 1000-BaseT Gigabit Ethernet port!
I can exclude a router misconfiguration, a bad router ethernet port or a bad ethernet cable, as I already performed the necessary tests with swapping router ports and Ethernet cables (the one provided with the S1 vs. a brand new STP Cat 5e cable of the same length).
So am I missing something?
Or is the Ethernet port of my S1 defective?
Or the current S1 firmware (which was updated to the latest version when initially connecting to EUCON) is not supporting 1 Gbit/s (yet)?
Thanks in advance, Eric
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD
Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins
PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder
Old 12-02-2021, 11:05 AM
EddieJones's Avatar
Default Re: S1 Ethernet Connection Speed
The S1 is definitely 1G. I just check my two and they are connected at 1G to my switch.
Old 12-03-2021, 01:02 AM
Thanks so much for this confirmation, Eddie!
Actually I haven't noticed any lags while testing my S1 so far: Despite of this connection mistery, it still feels much snappier than my former FaderPort, and it's probably also snappier than my old Digi 002 which I haven't used for more than 4 years
So I'll do some additional testing, in order to decide whether it's worth returning my S1 unit or not.
Old 12-03-2021, 07:14 AM
EddieJones's Avatar
The Artist Mix was 100M....even this is way more than EUCON needs. I don't know why yours is falling back to 100M but it's perfectly OK performance wise. I suspect something in the router/switch.
Old 12-03-2021, 09:35 AM
I never bothered looking at this, but just checked, and all 3 of my S1s and my Dock are negotiating with my Netgear GS308E Gigabit switch at 100MB/S - other devices are negotiating with the same switch at 1GB/S. I don't really care since everything works fine, but just thought I'd point it out. Latest firmware, latest Eucon build.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 12-03-2021, 10:34 AM
BScout BScout is offline
Checked. All my Eucon (S1 x 2 and Dock) are negotiating at 100M (not 1GbE.) This is to an HP enterprise switch using CAT8 cabling (everything else connected to the switch is running at 1GbE.)
At this point, I'm wondering how Eddie's devices are clocking at 1GbE.
Old 12-03-2021, 11:43 AM
EddieJones's Avatar
The Dock is 100mb the S1's are 1Gb. The do not need that speed though.
Old 12-03-2021, 12:22 PM
I've now checked 6 S1 units (besides my 2). All only can negotiate to 100M. (4 on one network switch LinkSys, 2 on a network switch Netgear; these beside my 2 on HP enterprise switch)
Any chance the contracted manufacturer changed NICs for cost? Does Jeff's units also show 1GbE. I can't even force negotiating to 1000M (only 10 or 100 half or full duplex.) I realize the speed isn't "necessary" but it is surprising that the units out there aren't living up to their hardware specs.
Old 12-03-2021, 12:40 PM
EddieJones's Avatar
I double checked and both the Dock and S1 are 100mb internally. My network switch when looked at side on showed light bleed that made them look like they were 1G :-/ Sorry for the confusion.
Old 12-03-2021, 05:02 PM
Cool. As you said, it's not necessary. Just started wondering if there was a hardware SNAFU. Glad everything is working as expected.
Ethernet connection JTC111 Pro Tools | Carbon 14 02-16-2023 07:25 AM
External SSD over Ethernet connection Emi Pro Tools 2018 5 01-21-2019 02:22 PM
C/24 ethernet connection jmtayloraudio ICON & C|24 3 04-23-2010 10:06 AM
No Ethernet Connection? Mark McCabe ICON & C|24 0 09-25-2003 11:44 AM
control 24 and ethernet connection ianmiller ICON & C|24 3 03-02-2002 11:24 AM
