Old 10-09-2013, 01:09 PM
MilesMusic MilesMusic is offline
Default Upgrade old licenses to AAX?
I have some older plugin licenses on my iLok from when I had an HD system a while back. Are these upgradable to AAX? e.g.: (Moogerfooger bundle, Pultec EQ)
Old 10-09-2013, 01:49 PM
TOM@METRO's Avatar
TOM@METRO TOM@METRO is online now
Default Re: Upgrade old licenses to AAX?
Yes, those two are.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-09-2013, 01:59 PM
How are the licenses upgradeable? I cannot find anything in the AVID store regarding upgrading old licenses.
thanks
Old 10-09-2013, 02:48 PM
Glenjb Glenjb is offline
Just download the new aax versions http://duc.avid.com/showthread.php?t=340211
Your licenses stay the same
Old 11-11-2013, 06:54 PM
jpbears1 jpbears1 is offline
I tried doing that and my old Moogerfooger licenses still won't authorize.
Old 11-11-2013, 07:38 PM
Southsidemusic's Avatar
Are you using these installers http://www.avid.com/US/products/Moogerfooger-Bundle
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-12-2013, 07:07 AM
Yep this link:
Moogerfooger_Bundle_11_0_0_Mac_79725.dmg
I installed them and they won't authorize. My iLok account has these authorizations:
- Moogerfooger Analog Delay (Avid)
- Moogerfooger Ring Modulator (Avid)
Old 11-12-2013, 10:44 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Check your ilok account. If the company name for these assets says "Bomb Factory", that's the problem. Contact Avid support and see if they can change them to say "Avid", that will solve the problem.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 11-12-2013, 12:43 PM
John and Southsidemusic - thanks so much for taking the time to respond! Much appreciated. Yes, the iLok authorizations say "Avid" under them and not Bomb Factory. How do I contact Avid support on this issue - it appears I need to pay them?
Old 11-12-2013, 12:56 PM
It is supposed to say Avid on them so thats not the issue. Have you reinstalled them and maybe repaired the licenses on the ilok key as users have been doing that and got licenses to work again. Try repair and see if that works from the ILM Program.
Also try to put the ilok in another usb port as it might reset a little bit so change ports after you repaired the ilok licenses from the ilok license manager and see if that does anything. Have you also VERY important, deleted the plists for both Avid and Digidesign under preferences so Pro Tools re-scans fresh plugin lists into the program and maybe that will help out so PT sees the new licenses. The old code needs to be replaced so delete both plists froml digi and avid.
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
HTML code is On
Can two PT licenses (same ilok) work in conjunction? Upgrade options? kh1 Pro Tools 10 1 08-06-2012 10:22 AM
Upgrade from HD8 to HD10, licenses questions, please Loudyman Pro Tools 10 15 06-04-2012 02:31 PM
Where to get licenses? joshua-starkey Pro Tools 10 2 11-25-2011 06:07 PM
PT10 - Free Upgrade for "Academic" licenses d.pacchi Pro Tools 10 0 10-22-2011 02:23 AM
