Old 05-06-2009, 04:29 PM
Bob Coulter Bob Coulter is offline
Default Pro Tools LE "Workspace"
When I open "Workspace" and then select one of my hard drive, the "Task Manger" pops up and says it's trying to synchronize that drive. The problem is it just keeps churning away and never finishes then usually crashes Pro Tools. It's fine with my other drives, just a problem with that one. Everything else works fine on that drive. Any suggestions what might be on that drive that's causing the problem?
Thanks!
Old 05-07-2009, 02:36 AM
tamasdragon tamasdragon is offline
Default Re: Pro Tools LE "Workspace"
Check out with disk utility if the drive you've mentioned doesn't have any problem. Is it mac os extended journaled? Is it external drive?
Tamas Dragon
my blog:Tamas Dragon
Old 05-09-2009, 03:45 PM
Pro Tools guys figured it out. It's working now. Thank you!
"Pro Tools not responding" error and a very "laggy" session! Help! drumbumd Pro Tools M-Powered (Win) 0 02-10-2012 06:37 PM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 07:45 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 05:49 PM
14 folders called "User Guide And Information" in workspace, and climbing. Delete?? skronger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-13-2011 11:17 PM
Cannot Change "P" to "R" in workspace. theprof_to 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-08-2009 01:24 AM
