Problems With External Drive For Storage (Not Recording)
I recently purchased a Seagate external drive for my Acronis ProTools backups and having issues with it. It either doesn't recognize the drive it all or locks the PC up. If I disable all the USB ports and reboot it, it "might" find it the 1st time however it makes the PC run at a crawl. If I restart the PC, it locks it up until I unplug the drive. I am certain it's not the drive because I can use that drive on my other PCs with no problems and I have the same problem with my 1 gig thumb drive on this (my dedicated audio) PC. Seagate won't help me because the drive works fine on other drives. I have updated the bios on the motherboard that the tech support from the company I purchased it from suggested.
F.Y.I. -I also tried a Western Digital MyBook external drive and got the same results. The PC is almost new so I can ship it back where it was purchased to be repaired but I was hoping I might get some suggestions here. I really don't want to give this PC up for two weeks and its works great except for this problem. All help appreciated! |
Re: Problems With External Drive For Storage (Not Recording)
Since the problem is related to the PC and not the drive, we will need more detailed information about the PC.
Hi spkguitar,
The PC is a Sweetwater brand Creative Station dedicated soley to running audio with Windows XP w/Service Pack 2. It contains a Pentium Dual Core 1.8 800 mhz processor, dual Seagate Glyph drives, Radeon X1550 video card and an Asus motherboard with the 945G chipset. The motherboard bios was recently updated from the Asus websight and is current. The PC is supposedly ProTools certified and tweaked for optomization. It has ran flawlessly other than this external drive thing. If you need any additional info let me know. Thanks. |
Yeah, it would help if you posted a sandra report. Instructions for posting details are at the end of the General Troubleshooting thread.
Most likely, though, it's a problem that none of us here are going to be able to help you with. It might even be a physical defect with the USB connectors on your motherboard. It's definitely a problem on the computer side of things since it happens with every device that you try. Here's something; are you using a newer version of Pro Tools? One that has the MacDrive HFS+ abilities? If so, try turning off the MacDriveService before you plug the drive in and see if that helps.
I am running PT 7.3 but not 7.4. Does 7.3 have the MacDrive HFS+ abilities and if so, how do I turn it off? I am experiencing the same problem with other drives (Western Digital MyBook and a Toshiba thumb drive). Thanks for your suggestions.
Additional info - The USB ports work fine with other USB items (wireless keyboard, mouse, M-Audio midi controller and etc...)
external hard drive for storage? | cordamusic | Getting Started | 12 | 05-13-2013 01:21 PM |
External storage problems | LockeClone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-15-2009 04:08 PM |
problems when recording to external hard drive | popswatch | Pro Tools M-Powered (Win) | 3 | 10-31-2006 04:00 PM |
Drive Formats (Storage Only, Not for Recording to) | AudioOIART | Tips & Tricks | 3 | 03-29-2006 12:08 PM |
External Firewire storage drive (Does 001 support yet) | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-22-2001 06:55 PM |
