Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
  #21
Old 06-11-2021, 09:39 AM
innerbooty innerbooty is offline
Default Re: Anyone running 2021 on old cheesegraters?
Well, this is a fun way to start my HDX adventure. Doing stuff around the studio and listening to some high-res 96K masters from a Pro Tools session. Very basic 96K session with only a few tracks. Nothing else going on in the computer, no firewire, no external drives of any sort. Only "extra" thing is that I am connected via Ethernet cable networked my old PT 10 HD Accel Mac. But PT and the session files are running off my brand new, mostly empty SSD drive in a SATA bay. Couple minutes into listening I get an AEA -9073 error and playback just stops. This is the kind crap I was so nervous about when thinking about doing a big "upgrade".
Screenprint attached. Don't suppose there's an easy fix/answer to this one...?
File Type: jpg Screen Shot 2021-06-11 at 12.28.37 PM.jpg (56.2 KB, 0 views)
  #22
Old 06-11-2021, 10:12 AM
I'm not sure what the problem might be, but you could try turning on Disk Cache in the Playback Engine settings. Sett it anything above Normal; usually best to set it to an amount just above the amount of audio data in your session. this will load up all of the timeline audio into RAM and free up disk bandwidth.
Scott Gatteño
  #23
Old 06-11-2021, 11:15 AM
massivekerry massivekerry is online now
2 suggestions.
1 - Absolutely use the Disk Cache, as ScottG suggested.
2 - If the SSD is in one of the sleds in those older Mac Pros, you are not getting full speed from it. The bandwidth on those SATA channels is only max 300MB/second. You can get double that, full-speed (max 600MB/second) by mounting the SSD on a PCI card (Sonnet and OWC make them). If you got clever and put the SSD in the spare (or main) optical bay, you'll only be getting max 180MB/second.
Kerry Smith
http://apothekerry.com
12-core 3.46GHz Cheese Grater, 64GB RAM, HD | Native, HD I/O
  #24
Old 06-11-2021, 11:23 AM
Thanks, yeah, I was thinking of pulling the trigger on one of those OWC 1M2 PCIe drives, which I think I will do now...
  #25
Old 06-11-2021, 07:14 PM
basslik's Avatar
basslik basslik is offline
Originally Posted by DetroitT View Post
5,1 12 core Mojave
Metal Vid 580, SSD Boot Spin Long Term
PT’s U HDX1
2021.3.1
DetroitT
Have you done the Open Core yet on your 580?
MAC PRO 2010 5,1 3.46hex 128ram - HIGH SIERRA - PT 2020.3 / 003 CONSOLE /DIGIMAX FS /PCM90 2CHANNEL SPDIF
  #26
Old Yesterday, 06:55 AM
I'm not sure what that is? You referring to the graphics card? I'm open to exploring things with that. I definitely having some weird issues since moving to Mojave and installing this (non Apple-flashed) MSI Radeon 560. I turned off all screen saver functions. Screen was black this morning, had to force reboot. Blurry snow screen at one point, force reboot. But that was before I turned off screensaver. Energy Saver been disabled all along...
Things seemed super stable while I was working on a High Sierra drive before getting Mojave going the other day. Does being in Mojave provide tangible advantages to being in High Sierra relative to running Pro Tools? Just curious...
I actually just ordered an Nvidia GPU, flashed for Mac, the other day, that I am going to try. On my third GPU. The first one I ordered turned out to require two PCIe power connections, and with the HDX card using one that threw me for a loop. It's been a journey. Definitely going to have some stuff to put back up on eBay at the end of this...
  #27
Old Today, 02:08 PM
off the wall's Avatar
I've got a 2010 MacPro 5,1 (see sig for specs) running Mojave/PT 2021.3.1 with no issues.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Radeon RX580 GPU, M.2 NVMe SSD boot drive on PCIe card, 64GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2021.3.1. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
No SRC in 2021.3.1 JanuS Pro Tools 2021 10 06-02-2021 07:55 AM
2021.3 and Catalina Thenewexhibit Pro Tools 2021 3 05-06-2021 04:57 AM
2021.3.1 innesireinar Pro Tools 2021 80 04-22-2021 01:31 PM
aside from 2021 upgrade, anything else? paul_g Pro Tools 2021 3 03-26-2021 08:25 PM
