Mbox2 Inputs Run Hot!!!!!!!?????
Hi, just got a brand new mbox 2 running it on a brand new iMAC 21.5 but virtually every 2nd time i turn on the mac/mbox and arm an audio track in pro tools for recording the signal is continuously peaking (with a bizarre white noise hissing coming through the monitors) nothing even has to be plugged into the inputs! nothing fixes it unless i unplug it and plug it back in???? whats going on??? any help would be greatly appreciated as this is one of many problems im have with my brand new system and im pulling my hair out! thanks guys
Re: Mbox2 Inputs Run Hot!!!!!!!?????
what version of protools and OSX are you running?
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
This happens to me too every now and then. Launch Pro Tools, record arm a track -- then BAM constant hiss that peaks the meter. Doesn't matter what the input is, can be mic or line in. Have to reboot and then it seems okay... until the next time it happens a few days later...
Mackbook Pro OSX 10.6.3 Mbox 2 mini PT 8.0.3 If it's not that, then it's a kernel panic from using sleep mode... |
10.6.3 also has not been qualified for use with PT, yet. I would, however, recommend trying the 8.0.3cs2 update and see what happens. Was this apparent before you upgraded to 10.6.3?
im running pro tools 8.0.3 and osx 10.6.3...is it a possible problem with osx do you think? or is it more likely to be an unfortunate mbox hardware issue?
The Windows community was having significant issues with white noise recently. While OSX may be the culprit in this case, I would recommend you upgrade to 8.0.3cs2 and see if this still happens.
ok will try it tonight and let you know thanks alot : )
I've had the "hot input" problem for a while now... I don't even remember when OSX 10.6.3 came out so I'm not certain if the problem was around before that. At any rate I just updated from 8.0.3 to 8.0.3cs2 this morning, and I'll let you know if that changes anything over the next few days. |
Hopefully that means this is the end of it... |
Not sure if this has been fixed for the OP but it seems the hot-input thing is still an issue |
Mbox2, no inputs in pt9- help! | leifthewarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-07-2011 06:51 AM |
Mbox2 Inputs Run Hot!!!!!!! | bennyj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-12-2010 02:27 PM |
i need more than 2 inputs, i have an mbox2 | mayhembrown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-09-2008 03:01 AM |
How many inputs, Mbox2 PRO? | Hemluth | General Discussion | 3 | 02-02-2007 10:04 AM |
4 inputs for mbox2 | jordan_ellipsis | Pro Tools M-Powered (Win) | 6 | 05-15-2006 02:26 PM |
