A Simple Porblem I Can\'t Figure Out - Copy Regions
Greetings....
I am a Sonar user that have recently started to use PT on a more full time basis. I know how to copy a region and even repeat or duplicate a series of regions. The question/issue is this: In Sonar one can lasso/select a group of clips/regions within a track or series of tracks and click CTRL, drag and copy the entire group to another location on the same timeline - a very fast way of copying tracks and clips. Is there a way I can do this in PT? I thought I seen this done before on a MAC...but I, for whatever reason, can't get this simple function figured out. Am I wrong to say that click CTRL-drag and copy is not a PT function? How do you manage to emulate similar behavior in PT? - KB |
Re: A Simple Porblem I Can\'t Figure Out - Copy Regions
In the top left of the edit window you will see the selectors for the smart tool. Click and hold the grabber and you will see three options; a hand and a hand with a scissors and and hand with a region in it. This is the option you want. It allows you to Lasso multiple regions across tracks
IMDB |
Also, holding Shift and selecting the desired regions with the Grabber achieves the same results. Then you also have the option of 'Group/Ungroup' command if running 7.x and higher.
filosofem
Aaron Mulqueen - 001 HD Native |
So if I hold the SHIFT key...would this essentially copy as I move the regions? Please excuse as I try to grasp the differences in hosts. - KB |
happy tooling a
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Look up region groups in the PDF help file
Sign up for all things....AWESOME! Kris May the music move you |
- KB |
Funny though I have a copy of Pro Tools LE 7 Ignite and in the Windows Shortcuts section it does mention the function that I am seeking...but it doesn't work. Weird. Anyway not crucial as I learned an alternative way to dupe regions. Thanks all..for your suggestions. - KB |
If you looking to just duplicate 1 or more regions, then why not just hold ALT and Left Click/Drag with the grabber in Grid or Shuffle mode? This will enable you to copy regions quite fast, and if you are working with a grid, this will work super quick, or if you need to use it over and over again, there is ALT+R. Hope this helps, as well if you want to duplicate backwards, then use CNTRL+START+ALT
Thanks. - KB |
Drag and copy regions to a different track? | Super Seven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-05-2012 07:06 AM |
Can´t copy MIDI regions properly... | Firechild | Pro Tools TDM Systems (Mac) | 2 | 11-25-2012 04:27 AM |
How to copy and drag regions? | pukeuv | Tips & Tricks | 15 | 08-01-2008 03:52 PM |
simple copy makes PT quit, Even more questions now | andre tchmil | Pro Tools TDM Systems (Mac) | 29 | 05-10-2007 03:27 PM |
Another XP Installation porblem | stevieg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-24-2002 12:50 AM |
