Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 07-15-2022, 02:05 PM
Zak7 Zak7 is offline
Default Pro Tools Carbon and Ableton Live on Laptops
Lets say I just want my whole studio system to work as intended but will bring different Laptops, yes I got the AVB connectors.
What should be the best way to run a ableton live session where the laptop runs everything and I just use PT carbon to monitor everything thru my speakers and use the mic press and instruments connected to Pro Tools Carbon?
what should be the best audio or playback engine etc?
Thanks
Old 07-17-2022, 04:08 AM
dominicperry dominicperry is offline
Default Re: Pro Tools Carbon and Ableton Live on Laptops
I don't understand any of what you're asking.
What does this mean? How did you intend it to work?
Do you mean PC laptops or MacBooks? Because I haven't read a single report of a PC running Windows working with Carbon and AVB.
What would be the laptop NOT running everything? What do you mean by "best way"?
Can you use Carbon with DAWs other than PT - yes.
Will it work with Ableton - I don't know. It does work with Logic.
You won't get any of the on-board DSP processing from the Carbon, and the round-trip latency in the DAW for monitoring might be pretty lousy, given that Avid's AVB implementation isn't very high-performance.
If you're using Ableton, then you will have to pick the Carbon as the audio interface in Ableton. I don't know how to do this, as I don't use Ableton, but it should show up as:
Pro Tools | Carbon I/O
Clearly the one marked
Pro Tools | Carbon: Reserved for Pro Tools
is not intended for Ableton.
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Carbon with Ableton Live darkwavo Pro Tools | Carbon 4 01-24-2024 06:39 PM
Pro Tools 12 with Ableton Live cellopoet Pro Tools 12 9 12-27-2015 07:09 AM
Ableton Live in Pro Tools 11 stuartmid Pro Tools 11 2 12-17-2014 06:40 PM
Ableton Live 8 & Pro Tools wfasano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-21-2009 03:16 PM
Ableton Live and Pro Tools Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-08-2002 05:07 AM
