The infamous Pro Tools "Play and Stop" plague
Yup. It strikes once again. I reinstalled (10.3.7), I don't have any cracked stuff, did all the optimization or so I think. It keeps screwing up my workflow.
Anybody cares to check my sandra report, maybe something's wrong in my bios or something... Thanks in advance SiSoftware Sandra Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS P9X79 PRO Serial Number : 1212063******** BIOS : AMI (OEM) 3203 11/26/2012 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (4C 8T 3.7GHz/5.7GHz, 3.7GHz IMC, 4x 256kB L2, 10MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : ASUS Core DMI2 (Sandy Bridge-E) 100MHz Memory Controller : ASUS Core (Sandy Bridge-E) Integrated Memory Controller Registers 100MHz, 4x 4GB DIMM DDR3 1.6GHz 256-bit Memory Module(s) Memory Module : G.Skill F3-17000CL11-4GBZL 4GB DIMM DDR3 PC3-17100U DDR3-2134 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-17000CL11-4GBZL 4GB DIMM DDR3 PC3-17100U DDR3-2134 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-17000CL11-4GBZL 4GB DIMM DDR3 PC3-17100U DDR3-2134 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-17000CL11-4GBZL 4GB DIMM DDR3 PC3-17100U DDR3-2134 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : LG (1600x1200, 19.1") Monitor/Panel : Hewlett Packard HP w2207 (1680x1050, 22.0") Video Adapter : ASUS EAH5450 Series (2CU 80SP SM5.0 650MHz/500MHz 30% OC, 1GB DDR3 900MHz 64-bit, PCIe 2.00 x16) Video Adapter : ASUS EAH5450 Series (2CU 80SP SM5.0 650MHz/500MHz 30% OC, 1GB DDR3 900MHz 64-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : ASUS EAH5450 Series (80SP 2C 650MHz/500MHz 30% OC, 1GB DDR3 900MHz 64-bit) Compute Shader Processor : ASUS EAH5450 Series (80SP 2C 650MHz/500MHz 30% OC, 1GB DDR3 900MHz 64-bit) Storage Devices Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) : 119GB (C:) Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (F:) Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (G:) ASUS DRW-24B1ST c (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 119GB (NTFS) @ Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) AUDIO (F:) : 2TB (NTFS) @ Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm) SAMPLES (G:) : 2TB (NTFS) @ Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm) Optical Drive (D:) : N/A @ ASUS DRW-24B1ST c (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS Patsburg LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASUS Patsburg High Definition Audio Controller Audio Device : ASUS Manhattan HDMI Audio [Mobility Radeon HD 5000 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS Patsburg 6 Port SATA AHCI Controller Disk Controller : ASUS Asmedia 106x SATA Controller Disk Controller : ASUS 88SE9128 PCIe SATA 6 Gb/s RAID controller with HyperDuo USB Controller 1 : ASUS Patsburg USB2 Enhanced Host Controller #2 USB Controller 2 : ASUS Patsburg USB2 Enhanced Host Controller #1 USB Controller 3 : ASUS ASMedia XHCI Controller USB Controller 4 : ASUS ASMedia XHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB-E XMB Ch 1 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet, 100Mbps) Network Adapter : Bluetooth Device (Personal Area Network) #2 (Ethernet) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 3.9 |
Re: The infamous Pro Tools "Play and Stop" plague
What interface? Is it firewire? Some Asus onboard FW controllers don't work. Is Wait for Midi Note enabled? Dynamic Transport enabled?
Interface information is very important. In my case, and many cases I've seen the fix is to toggle the buffer size in the interface mix software. If it's a focusrite interface, make sure you have the latest driver. THeir newest driver solved this problem for me.
By toggle buffer size, I mean, change it from whatever it is, and change it back.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Thanks guys for giving a [bleep][bleep][bleep][bleep]! In fact I have an Mbox3 with latest drivers. I use AKAI MPK61 for Midi Control. Native instruments work real good and other stuff too. Strange that the ONLY thing working wrong is the software that is supposed to be optimal for the Mbox.
In addition, I do not find any acknowledgment by AVID that the "screen freeze" but "session keeps playing in the background" is a "confirmed bug" and "We [AVID] are working on it". And just to make certain that I am not the culprit of my own problems, I have gone though all of the typical troubleshooting including: - removing my plugins folders (used and unused) - clean uninstall - delete: PT preferences, DAE preferences, etc. - reinstall PT 10.3.x - reinstall drivers for 002 - reinstall OS 10.6.8 (and also reinstall OS 10.7.6 on another drive) - Disk Utility for Disk Repair (was not needed on either drive) and Repair Permissions on both drives - NOT reinstalling ANY 3rd party plugins - tried all above with PT 10.3.3, 10.3.7, 10.3.6, and finally settled on 10.3.5 because I do not get the ["screen freeze" with "session continuing in the background"] as often with 10.3.5. OK . . . what did I miss . . . maybe something maybe nothing? AVID it would be great if you would . . . well, it would be good to have a progress report if there is one or if AVID considers these NOT to be an issue. It is hard to know when we do not hear from you. Sorry for all the background info but PT 9.0.6 keeps looking better and better, and that is a shame that I would even be considering such as a choice.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB |
The old "Stop and Play button" error | Trainwrecker | Pro Tools 10 | 9 | 03-24-2012 09:53 PM |
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface | eanderso22304 | macOS | 3 | 11-23-2011 06:45 AM |
Pro Tools "Sttuers" after quick play and stop | MichaelRHolloway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-05-2010 01:16 PM |
EastWest "Play" and Pro Tools 8 | Laughterbirth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 03-31-2010 01:46 AM |
If I "Remove Unused Regions" after "Consolidate", track won't play? | el biciclista | Pro Tools TDM Systems (Mac) | 10 | 04-02-2003 10:17 AM |
