#471
Re: -9171 and -9172 errors with Pro Tools HD 10.3 on HDX
Hi all. Just a quick update on this issue.
I finally got to installing 11.2. I also updated to ML 10.8.5. While I can't say that the issue is completely fixed. I DID notice an IMPROVEMENT in the 96k 24bit recording at 64 buffer on my HD native system. My initial tests were 1 stereo instrument with SSD4 5 mono audio tracks each with Eleven. 1 Mono audio track with Waves GTR Bass The best results came with the following settings: Buffer: 64 Delay compensation: off Dynamic plugin processing: off Low Latency monitoring: off Just running test tones and basic midi loops through the instruments the 9171 and 72 errors still came, but noticeably less frequent. As I said. Its an IMPROVEMENT but I don't think 64 buffer is ready to use for sessions or projects. But this was a step in the right direction. The best and most usable settings were: Buffer: 128 Delay Comp: Off Dynamic Plugin Processing: Off Low Latency Monitoring: On Everybody else share your findings with 11.2 Thanks
Mac Pro 5,1 2.4GHZ 8 core OSX 10.8.5 PTHD 11.3 HD Native HD MADI Artist Mix |
#472
Thanks for sharing. I don't see them that often anymore. But then again I run mostly with buffers above 1000...
#473
I'm getting this more and more now with post sessions. PT 11.2.1, HDX, 512 buffer, 2011 MBP, i7, 16 gigs of ram, ML. SSD BOOT drive, 2nd 7200 rpm internal drive for sessions.
#474
Which OS are you using
#475
I'm on Mountain Lion.
#476
Which version
#477
Greetings! ML 10.8.5
#478
I used to run PT on OSX 10.8.x.
Here is my solution: I installed OSX 10.6.8 on a new drive, then I installed PT 10.3.9 and all plugins, including the latest Waves V9.3 that are supported from 10.7 and above. Everything works super smooth and no more 9171 and 9172 errors. 10.6.8 works faster and better than 10.8.5 in many areas, including Pro Tools.
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
#479
Any latest with this, or over at the duc? I've been trying to speak with Avid Tech for a while and no real results and they hardly seem to acknowledge the issue. However, after much research I do NOT think that it is pro tools or HD|Native per se. I can get this to happen in Logic and with Internal Speakers/Audio set.
Also, my issue might be a little different, but I would definitely characterize it as CPU spiking. Here is my system: PT11HD HD|Native Mac pro 5,1 12 Core 3.06 (2012) 16gb RAM 11.2.1 Lynx Aurora (using HD Interface) I can open slate VTM and just click SHOW/HIDE to display the tape machine graphic and get my CPU to hit 100% (or higher in Activity Mon) every time. If I'm playing audio, this will stop playback with an AAE error. VERY Odd. Switching instruments in VI's can cause this, and so does toggling record ARM repeatedly with several tracks with plugs on them grouped together at once. I come recently from PTHD TDM where life was a bit limited but good. Now life is limited (in a different way) and not good at all. I did DISABLE Hyperthreading (not use XCode but using a Sudo Command: OFF: sudo nvram SMT=0 ON: sudo nvram -d SMT This keeps it off even on reboot. It's obviously working because sys†em usage only shows 12 cores for me now. ***This makes quite a difference for the better! Another reason why I think it's OS based - or at least an interaction between multicore processing and a given software. Like I said, I can get spikes to occur without using the HD|Native card and using a different software - one made by Apple. Anybody else experiencing this Show/Hide CPU spike issue with VTM? It's an easy way to see it happening. When I called Slate, they weren't able to get this to happen but I've tried this on other machines and other vanilla installations - no difference - at least with AAX and AU. But in general, even with my fast computer, I still get all sorts of CPU 'movement' on the monitors (activity mon and sys usage) without any real reason. ==== Does 10.6.8 work with 11HD? No? |
#480
Great tip on disabling hyperthreading. Thanks for that. Now I can retire my Automator action.
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
Pro Tools 10.3 9171 and 9172 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 20 | 07-14-2013 03:11 PM |
-9171 and -9172 errors constant...Sandra attached | wrachilla | Windows | 12 | 05-09-2013 09:19 AM |
UAD triggering 9171, 9172 errors? | xq3js | macOS | 7 | 03-22-2013 11:47 PM |
Dae errors -9171 after installing 10.3.3 | TCM | Pro Tools HDX & HD Native Systems (Win) | 3 | 02-06-2013 10:18 AM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
