Old 04-18-2002, 08:14 AM
Haniel Trisna Haniel Trisna is offline
Default Error type 3 on HD system
just thought someone knows why this is happening,
on one session yesterday I get Error Type 3 everytime I quit ProTools and relaunch it. When the error occurs (seems like during WaveShell3 load), the launch process hangs, and I had to do a hard reboot. Is there anyway to gracefully kill a process (a'la Microsoft Task Manager or UNIX kill -9 procname) without hard reboot ?
I imagine the hard reboot can't be good for the filesystem.
[img]images/icons/grin.gif[/img] Hey, this is my first crash with Protools (user since January) I thought PT is supposed to be perfect .... [img]images/icons/wink.gif[/img]
Thanks,
Haniel Trisna
Mixermaster
mixermaster.com
Old 04-18-2002, 08:56 PM
audio1234 audio1234 is offline
Default Re: Error type 3 on HD system
I dont know if you have a Midiman USB interface,but if you do try turning off the extension.This problem will go by by..
Old 04-19-2002, 05:33 AM
DigiTechSupt's Avatar
<font size="2" face="Verdana, Arial">-Although not perfect, you can Force Quit the application:
Command+Option+Esc
-Even if you are successful getting back to the Finder, I would suggest restarting the compuer.
regarding the type 3 error:
-Trash the DigiSetup File, Pro Tools preference, and DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and restart the Mac.
-Since this is specific to 1 session, it may be corrupt. Create a new session, use the File>Import Tracks command to transfer the tracks into the new session file.
-Increase the Preferred Memory size of Pro Tools by 50-60MB. Never change the Minimum memory size. If you have, you can set it back to the default setting by typing a 0 into the field and press Enter on the numerical keypad.
Brent
Avid Audio Tech Support
Support FAQ
Old 04-19-2002, 09:56 AM
blanos112 blanos112 is offline
I had exactly the same problem in an HD system after I installed the cs2 version of 5.3.
Old 04-19-2002, 03:42 PM
What does trashing these 3 files actually do ? Does it reset some preferences that I have to redo ?
Originally posted by DigiTechSupt:
<blockquote><font size="1" face="Verdana, Arial">quote:<hr /><font size="2" face="Verdana, Arial">Originally posted by Haniel Trisna:
Command+Option+Esc
Brent
<hr /></blockquote><font size="2" face="Verdana, Arial">
Haniel Trisna
Mixermaster
mixermaster.com
Old 04-21-2002, 03:51 AM
ODC ODC is offline
Hi there !
Same problem for me, error 3 when quiting the soft, sometimes freezes when lauching after Machine control plug starts....
G4 933, 1 Giga Ram, HD2, Atto Express PCI, Miro DC30+, Basic extensions set, OS 9.2.2.
Hey Digi, I trashed the files but that not helps !
I FEEL BAD ABOUT THIS [img]images/icons/mad.gif[/img] [img]images/icons/mad.gif[/img] [img]images/icons/confused.gif[/img]
Old 04-21-2002, 07:37 AM
Do any of you have the Midiman USB interface?If you do it is without question your problem.Error type 3 are Mac OS error's when the finder quits it has lost ram allocation trashing the preffs, may for the moment solve the problem but it will be back,along with some error type 2's.
Old 04-21-2002, 08:50 AM
burningbusch burningbusch is offline
I've experienced similar problems. I just switched from a rock solid Mix3 to HD3. The errors pop up during loading of PT 5.3. I created a new boot partition with a clean install of OS 9.1 and reinstalled only the apps that I absolutely need. So far it has been stable. HD and 5.3 has been considerably more prone to these errors than Mix and 5.1.1.
No I don't have a Midiman USB interface.
Busch.
Old 04-21-2002, 02:21 PM
ODC ODC is offline
Hi everyone !
I don't use any MidiMan USB Interface, I use a Emagic Unitor 8 MK2.
I feel the same with the HD system, as my last Mix5 was REALLY rock solid.
But, I have to say it was running on a G4/450 mac OS 9.0.4.
Do you guys think a PT update could fix it ????
Old 04-21-2002, 07:43 PM
I don't even have a MIDI interface. My setup is exactly this:
PowerMac G4 733 (new), HD3, ProMax DH Max dualhead video, 2 Maxtor ATA 133 drives in addition to the ATA that ships with Mac, Kingston SDRAM 512MB in addition to the 128 MB that ships with Mac.
Haniel Trisna
Mixermaster
mixermaster.com
Type 2 error - system failed? Mac OS 9 GrahamCA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 03-16-2008 08:38 AM
Type 10 error for OS9 system Janvy Pro Tools TDM Systems (Mac) 0 08-11-2004 07:54 PM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
HELP ! ! PowerBook G4 error Type 3, Type 2 HELP ! ! Liquidtrek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-18-2002 06:28 PM
System Error Type 10 - why with PitchDoctor? HughM Pro Tools TDM Systems (Mac) 2 11-23-1999 06:55 AM
