what pop filter should i get?
i want to get a very good pop filter for a female vocalist who has serious sibilance issues.
i've noticed one by Royer, and i recall some other one but don't remember the name. ? |
Re: what pop filter should i get?
I like the Stedman Proscreen.
How does it sound, you ask? Like it's not there. It simply removes the plosives that cause problems. But no pop screen is going to have much effect on sibilance. In PT, use a plug-in de-esser, preferably Waves. The Digirack de-esser will also work, but it's veiled sounding.
iMac i7 2020 Monterey 16GB HD Native Thunderbolt |
http://www.prodigy-pro.com/SearchRes...x?CategoryID=9
Check those out, at the top. The filter part is really sheer but its double sided and the distance between the front screen and the back screen is a little under 1cm. Since I've been using it I've been able to put the singers pretty close to the mic without worrying too much. Good stuff! |
"Popless" is pretty good, you can add up to three filters in series to avoid the big pops. But pop filters are bandaids, start with the vocalist. Train her not to pop her P's, B's, T's, and other cons. Next, mic placement and settings. If you are using a hyper-cardiod setting on like a 414, there's a higher proximity effect (more bass more popping). You might want to set the microphone at an off axis angle to the left or right of the performer. It helps when they aren't splattering all over the mic. Then try the pop-filters.
Another trick is to use protools plug-in automation to just automate excessive bass on just the plosives. Mike Lattimore www.mindtheatreaudio.com |
What do you guys think of the ones that are all metal (as opposed to fabric)?
seriously, save yourself 15 bucks and stretch out some panty hose on a coat hanger. i am small time, but my friend makes millions on his studios and in every one he has the pop filter i just described. it has a humbling effect.
I’ve been using my wifes’ stockings for years! [img]images/icons/wink.gif[/img] Just make a metal ring and pull the thin fabric over, there will be two screens close together, wich might be one of the reasons it works so good. It does the job without dulling the sound.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I’ve been using my wifes’ stockings for years! [img]images/icons/wink.gif[/img] Just make a metal ring and pull the thin fabric over, there will be two screens close together, wich might be one of the reasons it works so good. It does the job without dulling the sound. <hr /></blockquote><font size="2" face="Verdana, Arial">you know that works im sure fine, but if you've got multiple clients, i don't think your 2 oclocker wants to smell what your 10 oclocker ate for breakfast, mixed with smokey and whisky breath.. the stedman is metal, put it hot water with soap, dry it off, its new again.. you can get em pretty cheap on ebay im sure.. tim |
Help! Pop filter not used | pmc2013 | Pro Tools SE and Essential (Win) | 7 | 10-23-2013 09:20 AM |
Asking About Filter | Kade B | Tips & Tricks | 2 | 02-21-2012 01:06 AM |
pop filter | hef | Post - Surround - Video | 1 | 07-02-2008 12:35 PM |
Any good Filter / Step Filter Plug-ins? | Jsswtpmp182 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-07-2006 05:01 PM |
pop “filter” | Fritz | Tips & Tricks | 3 | 12-03-2003 08:28 PM |
