Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 08-27-2021, 07:06 AM
its2loud its2loud is offline
Default Re: Playing Mac Audio Through MTRX Studio
If you’re gonna go with the external audio interface and then another analog to Dante out, then skip the middle man and go with this if you don’t want to deal with DVS.
https://www.audinate.com/products/de...BoCVBUQAvD_BwE
Old 08-27-2021, 11:16 AM
Sardi Sardi is offline
Originally Posted by creativecontrol View Post
Even if you had a legacy Mac (or TB Dock on a newer Mac), the MTRX Studio doesn't do Optical SPDIF - which is what you would need, ADAT only.
Is that right?
Well that’s a shame.
Old 08-27-2021, 12:02 PM
Jeff Schmidt Jeff Schmidt is offline
I have the I/O card in my 2019 MP, but I opted to use an old MOTU Ultralite Traveler interface just for Sys Audio.
That said, I just picked up the MTRX Studio and will eventually be doing Sys Audio via Dante.
2019 Mac Pro 7,1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate, or whatever 2022.6 is called now
HDX 2 w MTRX, Dadman
9.1.4 Dolby Atmos over Dante to external RMU
Old 08-27-2021, 12:31 PM
devinemke's Avatar
devinemke devinemke is offline
i use a Blackmagic UltraStudio 4K for video playback (via Thunderbolt on a 2013 MacPro Trashcan). i feed the AES out of the Blackmagic into my MTRX and have it configured as a stereo source in DADman on my S6 MTM. i then have it configured as the default sound output in my Mac system preferences. works great, and works regardless of whether Pro Tools is open or not.
hope this helps.
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 08-27-2021, 05:08 PM
rmccam rmccam is offline
Thanks everyone for the replies.
I have a 2019 Mac Pro, so not optical out, unfortunately. With my OMNI I was coming out of the headphone port into a Radial J+4 but I was hoping to not waste the inputs.
I was just sort of thinking the Dante solution might be a good one but there are a lot of people grumbling about it so analog might be easier.
That said, I have an Aja KONA LHi. There might be a more elegant solution with that.
Thanks again.
Ryan McCambridge
Producer • Sound Designer • Mixer
  #16
Old 09-03-2021, 11:09 AM
Even though DVS gets a bad wrap - it can still work just fine for system audio - otherwise pivot to James' external audio interface recommendation.
Jeff
Hi Jeff - I'm trying to wrap my head around a solution to this issue for a client's setup that has a full MTRX with some Dante hardware interfaces (IOW, Dante is already running on this system and is part of the DADMan setup).
What would be the 'approved' way of getting CoreAudio into this setup (without additional hardware)? Since it's not my system, I'm not looking at it right now - the solution may be obvious, but would love a little guidance here.
Thanks!
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
  #17
Old 09-03-2021, 11:18 AM
creativecontrol's Avatar
Well that's pretty simple. Without hardware = DVS. With hardware = various digital audio devices which include a hardware Audinate chipset. Alternative discussions here have been about clocking a device (like a video peripheral) externally via AES and having it simply follow the rate change introduced by master clock = MTRX.
So for CoreAudio software based Dante connections - DVS is pretty much it.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #18
Old 09-03-2021, 12:10 PM
K, thanks for your input Jeff!
  #19
Old 09-09-2021, 01:53 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
I've been using RME HDSPe AES card for just this purpose, I got sick of Dante not switching with changing samplerates etc... so now the AES card looks at the incoming clock (from Avid MTRX) via input AES1 and switches accordingly. Works great. The sessions I get to mix are all over the place (clockwise), so to get sound (from my MacPro), I first had to switch the clock with Dante, which drove me nuts.
Can highly recommend RME HDSPe AES card, I see now your using MTRX studio, so probably your best solution is the RME HDSPe RayDAT card with ADAT optical connections.
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
  #20
Old 09-09-2021, 08:17 AM
Nice solution!
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
MTRX Studio Audio Midi Setup Goombot Pro Tools 2020 6 02-25-2021 08:35 AM
MTRX Studio to Mac Core Audio? Cheesehead Pro Tools | MTRX & MTRX Studio 10 08-31-2020 04:59 PM
MTRX not playing back 96k audio from Pro Tools djkrayz Pro Tools | MTRX & MTRX Studio 4 08-25-2020 09:46 AM
