Track input monitor and recorded region too during playback
I'm coming from Logic, so I tend to replicate in PT some Logic behaviours that I am used to.
Now, in Logic there is obviously the Auto input Monitor option in Record mode, as in PT. Well, if you disable it and the track is armed, playing back the song you can contemporary listen to both your track input monitor and the recorded region too. At the moment in which you click on "Quick punch record" obviously the recorded region disappears from the ears, making place to the new recording. This is useful for me, because the singer often wants to make a little try just a little before the punch in point, but he also wants to listen to the already recorded takes, so to better identify himself with the old take.. I can't find this behaviour in PT. Ins't it there?
MUSICNET STUDIO Via Puini, 97 57128 Livorno ITALY |
Re: Track input monitor and recorded region too during playback
Try Pre Roll and Post Roll.
I do a lot of Described Video and need to punch and roll. You can use Quick Punch and just playdown from wherever the Talent wants to hear from and Quick Punch in at the place where the new vocal is going. I find it's easier to not use/have the Transport in Quick Punch and just highlight the area to be replaced and put in a sufficient Pre Roll amount to get the "flavor" of the already recorded take. The Transport will play from the Pre Roll point the length of the Pre Roll and then drop into Record at the beginning of the highlighted area, record to the end of the highlighted area and then either stop or play the already recorded material the length of your Post Roll. You may also find it useful to use Selection Memory Locations Markers to get back to the same areas and with the same Pre and Post Roll Values.
Take your projects to the next level with a non-union national read at reasonable rates Demos: brucehayward dot com SonoBus Source-Connect: brucehayward Options for Remote Direction Last edited by The Weed; 08-18-2021 at 11:11 AM. |
Yeah! I tried it. All you wrote works, And also memory location is very useful. But here this works only in Track Input mode. The disadvantage is that, every time that I want to re-listen to the just recorded take, I have to change to Auto-input mode, or disarm track. And If I want to record and listen every time, I have to continuously change input / auto-input mode... It's not a tragedy, but even not so comfortable
The routing you use makes a difference. In my experience, some routing requires the track to be in Input Only. If you have PT Ultimate, there is a Preference to "Disable “Input” When Disarming Track (In “Stop”)". If you only have Standard, Shift+I is your friend.
"playing back the song you can contemporary listen to both your track input monitor and the recorded region too. "
This is confusing to me(especially the word "contemporary" in this context. maybe some translation software is confusing this?). How can you listen to the input AND the recorded audio? Of course, if you use an interface that allows for mixing the input WITH the DAW, then I understand, but that's a function of the interface. In PT, to listen to both playback audio AND recorded audio, you could put up an AUX track using the same input. That would allow you to hear your live input all the time(and might cover your needs)
Conversely Auto input monitor ON behaves as PT Quote:
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I use Apogee Element 88, I don't think it's an own Apogee function. I could get wrong but I think it is a Logic behaviour
Albee’s suggestion of using an AUX track for your mic input is a viable solution within Pro Tools.
Feed the cue send from the AUX track and you will always hear the mic input. Alternatively, your Apogee interface has dedicated software for creating custom headphone mixes within that software so you can hear both the Pro Tools output as well as the microphone input. If you don’t have the Apogee Control software, here’s some info https://apogeedigital.com/products/element/control |
Newly recorded region will not playback | teacherman | Pro Tools TDM Systems (Mac) | 1 | 05-10-2019 11:23 AM |
Problem with input monitoring vs. recorded track PT 10 HD | Snowy | Pro Tools 10 | 2 | 08-28-2015 10:49 AM |
Monitor a pre recorded instrument track bussed to Audio | pipco | Pro Tools M-Powered (Win) | 0 | 04-13-2011 09:05 PM |
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? | awhile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-17-2010 07:50 AM |
newbie ? Can't monitor new input & recorded stuff | Lugh98 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-06-2005 05:56 PM |
