#41
Re: GUI freezes frequently with 2021.6 on M1 Mac
#42
Beach ball persist. so far I tried everything i read
#43
Pedro, have a read of that last page of this thread
https://duc.avid.com/showthread.php?t=416815&page=5 I've done a test removing Waves plugins to see if the beach ball goes away. If you'd like to do your own test and report back it would be interesting to hear what you find. The community thanks you |
#44
I'm going through the same problem. Protools 2021 - MacOs BigSur
#45
To repeat myself, I do not see it here. Not even after first updating to PT2021.7 and later to macOS 11.6 -- BUT (and a very big but) there is this thing called clean install that I did instead of updating over updates and another updates after factory install.
#46
There's a guy on the Presonus Forum (PreAI) whose reponse to absolutely everything is "check you've got the latest drivers, update every plugin". He says it regardless of the issue and defends it vigorously at all times. It's very dull and it's a distraction from actually fixing stuff or revealing where the application is at fault. So, you've said your piece - you don't have problems and you believe that a complete 'clean' reinstall of the OS, and then everything else will fix this issue. The fact that earlier version of PT do not have this problem, and that downgrading back to 2021.3 seems to be a fix for most, if not everyone CLEARLY points to a fault with the latest two versions of PT. Dominic |
#47
I am just sayin' because of my beta testing background I know (not guess) it is always best to get rid of as many variables as possible. Clean install and getting rid of plugins are such methods. If you have a random error and a random install, you have random chance to figure out what to fix.
#48
I support Jannes point about clean installs. I've been a believer in this for decades. Big part of my having stable working systems. I wish some one with these problems had the time and an empty drive to test it. Two or three hours should do it. And make backups along the way in case problems arise again. That's troubleshooting. Added: BTW, I disagree strongly with Janne and others' determination that Migration assistant should be avoided. The only thing it fails at is transfer of large complicated programs like PT. I use it everytime I do a clean install, and as long as I deselect transfer programs, everything works fine; licenses, system settings, preferences, contacts, bookmark, passwords, everything. Makes the whole thing doable in an evening.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
#49
It is always nice to read a supportive comment, but you are right -- I am not here for that. Same goes for any other moderator; we are here to help.
I do not care what people think about my posts. I mostly present facts, and if on a bad day someone gets under my skin I can also apologise for being rude. Publicly or privately, if I am out of line just say so. But out of my thousands of posts I would guess very big percentage are on the point. Thanks Ben!
#50
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1 |
Protools 2021.3.1 slow to load and then freezes | BarefootWarrior | Pro Tools | 0 | 04-22-2021 08:59 AM |
2021.3 Installation Freezes Computer | gregklau | Pro Tools | 5 | 04-04-2021 10:06 AM |
New laptop-windows freezes when starting a session on win7 64 | reltucdc | Pro Tools M-Powered (Win) | 0 | 10-28-2010 09:55 AM |
Computer freezes when starting new session | Archie Gates | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-27-2000 12:09 AM |
