Old 04-24-2015, 10:10 PM
lanstrad's Avatar
lanstrad lanstrad is offline
Default MIDI playback out of sync ?
First time I'm trying a real MIDI (not soft-synth) with PT.
While the exact same IN/OUT plays perfectly in sync under Cubase, if I try the same setup under PT, the playback of my external module is completely out of sync...
Any idea why this would be ?
1) created a midi track
2) set IN to Axiom Port 1 (USB)
3) set OUT to a Roland XV-5080 sound module
I'm not drunk I play straight... But playback is delayed by about 1/2 note!...
And I used a Boom box on that project, which tells me I'm following the same midi clock...
Rob
____________________
Mac OS X Catalina (latest) (on Mac mini 2018) 6-core Intel i7 32GB ram 3.2 GHz. Interface: Universal Audio Apollo X4 (Thunderbolt 3 connection)
midi express 128, Pro Tools 2020, Cubase Pro 10.5/
Old 04-25-2015, 11:20 AM
priorytools priorytools is offline
How are you monitoring the XV ?… Is it coming into PT on an audio track with input monitoring ? And how is that track routed to your outputs? Via a sub bus?
Also, check your buffer settings
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 20.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V20.11.1.10 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
MIDI Playback out of sync Voice Crafters Windows 4 04-22-2014 02:26 PM
midi display and playback don't sync up freakhouse Pro Tools 10 4 06-26-2013 07:39 PM
Midi playback out of sync after editing layres Pro Tools 10 1 01-17-2012 08:36 AM
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
Sync Processor's Tremolo to Midi Time Sync via Interface j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-01-2000 12:08 AM
