Old 03-22-2023, 03:27 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: VST/VI Stops Playing
Originally Posted by Audiofarm View Post
I have this issue after a cpu overload message. Not the one with instrument assignment to none but it just stops playing so I have to deactivate/activate the VI..
I've seen that too.
MSI Pro Z690-A | i913900k @ 5.5GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 03-22-2023, 06:55 AM
Carl Lie Carl Lie is offline
Yes! that does seem to be what makes my VI's drop.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 03-23-2023, 03:07 PM
clarinetdelune clarinetdelune is offline
Unfortunately, mine is happening regardless of CPU/Buffer overloads. Super frustrating when there's lots of MIDI work to do and clients are in the studio!
Intel Mac Mini 3.2 GHz 6-Core Intel Core i7
Mac OS 12.6.3
Pro Tools Studio 2022.12.0
Lynx Hilo USB
Old 04-09-2023, 06:06 PM
I've just had this happen again repeatedly with clients in studio. Most interesting thing is that when this occurs, not only will the VSTs go offline, but the click also stops registering as well. I have double checked to make sure that the click is on, which it is, but the "Click" insert isn't registering and playing.
Mac OS 12.6.3
Lynx Hilo USB
Old 06-06-2023, 02:50 AM
midnightrambler midnightrambler is offline
Yes I've had this as well - for me it's like the MIDI engine just gives up and stops running, so some (sometimes all) VIs and the clik stops working, but the audio carries on playing fine. In my case it's when there's a CPU overload - in my case, a Guitar Rig 6 plugin that was causing havoc (and specifically one setting which doesn't even run MIDI, so not sure why that would make it throw a wobbler...)
  #16
Old 06-06-2023, 06:32 AM
Tweakhead Tweakhead is offline
same here. my workaround is to record or place the MIDI data on a simple MIDI track, and route the MIDI to the desired instrument. an inconvenient waste of time and space of course, but it's more reliable.
  #17
Old 06-06-2023, 10:10 AM
ejinbc ejinbc is offline
Yo
Same here - stopped paying for updates at 2022.10. Midi routing lost very occasionally, but no sound from VI once every week or so. Reboot required, then all well.
Given the number of respondents, Avid must know this is a thing.
Looking forward to reinstating my perpetual license the minute there is a meaningful update for Windows users.
ejinbc.
  #18
Old 06-06-2023, 10:13 AM
chompers2022 chompers2022 is offline
These issues have been happening for several years. If a re-assign the instrument to the correct path it fixes it.
  #19
Old 06-06-2023, 03:14 PM
Also have issues on occasion where VIs aren't running when bouncing a mix, then they suddenly thump in halfway through. Doing it on both my rigs (i.e. issue not computer or OS specific)
  #20
Old 06-07-2023, 09:59 AM
kindkind kindkind is online now
This happens on my system frequently, i usually drag the instrument to another track and then drag it back and it begins to work again. I will also try deactivating as i have experienced crashing PT when dragging to certain other tracks such as those with an instrument already on them.
Mac Studio M1 Max, 32gb, 2022.12 ultimate, HDNTB, Aurora 16 LTHD, 12.5.1
AUX Buss stops playing Intransit Pro Tools 11 2 05-28-2014 02:29 PM
DV stops playing via canopus MESH@ZU Pro Tools TDM Systems (Mac) 8 09-20-2007 08:18 AM
iTunes stops playing Sunzate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-06-2006 08:26 PM
m-box sound stops playing S.p.Z 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-03-2005 08:27 AM
G4 AMIII stops playing joepopp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-19-2002 01:18 PM
