#31
![]() Quote:
If you work for AVID, good for them, this is how clients should be treated. If you don’t, good for you and YOUR clients. This is great great info. Thank you. Hopefully AVID will not delete THIS thread of mine so others in my position can benefit as well. IdeaScale, personal conversations, and the locked/deleted posts say they’re out there. Cheers! |
#32
Work for the film/tv industry in post (nothing to do with Avid) but on Pro Tools all day/every day
Pro Tools Ult 2023.9, HDX 3, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, FireHD x 2, Dock, iPad • Mac Mini 14,12, 12 core, macOS 13.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#33
![]() Quote:
Used to be able to mix with my eyes closed on my Command 8. Similar sort of thing when I used to work at a full studio on a board. Artist Control never gave me that level of confidence. I get the feeling that the S1 could get me there again. Again - very kind of you to provide your help to me and the community. |
#34
![]() Quote:
"the track could not be input monitored because it doesn't have both an active input and output assigned" The track clearly does have both assigned (and tested to verify). When I click the "I" icon in the pro tools mixer it works as expected. Any idea why this might be happening? |
#35
![]() Quote:
#36
![]() Quote:
If I create a brand new session with only a few tracks it works exactly as it should. When I open an existing session with many other tracks/types, it doesn't work using the same I/O. When I add a new track (in this same problematic session) it not only works on the new channel but the old channel that didn't work 30 seconds ago suddenly starts working. Closing the session and re-opening starts the cycle all over again and it doesn't work until I add a new track, input monitor the new track and then go back to the older track which, again, suddenly starts working. I wish it was user error but it sure doesn't seem to be... |
#37
Put in a error note with Avid through the Avid Support Center. Include in it the corrupt session (no media) so they can recreate the steps you have. And then list your steps. You can even send your softkey Eucontrol file so they have the softkey exactly as you have it programmed.
Only they can "look under the hood" to see what is happening.
#38
As Bscout says PM me the session with exactly the workflow step by step to show me the issue.
#39
Thank you both for your willingness to help, however I seem to have fixed the problem (at least for now). Yesterday I removed and re-instantiated all Eucon devices, trashed my PT prefs, started a new session, imported the tracks from the problematic one and now it seems to be consistently working. I wish I knew exactly what fixed it, but I'm happy that all is good now.
I'm curious though, why the Shift key on the bottom left of the S1 doesn't offer the same functionality? It toggles the rec arm regardless of whether the shift key is engaged which is kind of a waste of a modifier key. Seems like it should be a natural extension of the functionality to match the Shift key on the Dock. Maybe something that could be added in a future update? Last edited by zakco; 06-07-2023 at 01:41 PM. |
Track input monitoring from control surface | Neale | Avid S1, S3, Dock and Control App | 6 | 05-15-2022 06:26 AM |
Track Input Monitoring in 12.2 | john1192 | Pro Tools 12 | 1 | 09-08-2015 11:59 AM |
track input monitoring | vin7 | Pro Tools 10 | 6 | 08-28-2012 07:08 PM |
Using a 01V96 as control surface AND input board? | JCBigler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-23-2006 07:45 PM |
Control Surface / 5.1 Monitoring | Dabbler | Pro Tools TDM Systems (Mac) | 1 | 03-10-2006 05:48 PM |
