Hello,
I am posting this on behalf of a friend whose studio I am working at. They have a MIX system with 3 888/24's. Running off a G4 Quicksilver with 1Gb of RAM, currently 10.3.9 and Pt 6.4.1. Within the past month or so, they have been having a problem where the volume of one or two outputs of the 888s will randomly change by 10dB or more. The fader value and output meter in the PT mixer will stay the same, but the volume coming out of the 888 will change suddenly, either getting way quieter or way louder. For example, a guitar track may be peaking around -6 on the internal mixer and the 888 meter, but then suddenly it will be slamming all the way into the red on the 888 meter (and coming out of the 888 much louder) but still be showing a peak of -6dB in the PT mixer. The fader in the Pro tools mixer doesn't move so it's not an automation issue. Usually this happens to two channels at a time, but it could be any of the 24 outputs. The internal system drive was completely erased and reformatted, the PRAM/NVRAM etc. were zapped, OS X 10.3.9 was reinstalled and PT 6.4.1 was freshly installed. There are no plug ins being used. All cards were reseated, all cables were disconnected and reconnected. Never even heard of this problem before and I have been using PT for ten years! The studio owner tried to call Digi tech support and was basically laughed at for not upgrading to HD (which they can't afford) Any ideas? Anyone have this problem? Sounds like bad hardware I guess...could it be bad RAM? Chris |
If you are not using v6.4.1cs4, install that and let us know if the issue persists.
OK, we'll give that a try. Thanks.
Haven't had the chance to install yet, but the problem only happens when using sessions with +12dB faders...so it seems consistent with the bug mentioned in the cs updates...sounds like it will fix the problem. Thanks!
I ran into this same bug about 18 months ago. LONG (LONG LONG) story short, it's a known bug that when 3 888's are used on a Mix Plus system in a +12 session this error will occur. At the time, though DIGI claimed that the latest cs release had fixed the problem, it had not. I don't know if they ever did fix it. I'll see if I can't dig up my posts from when I went through this becuase I got some very helpful replies. Again, there was no fix at the time, but there was a workaround that had to do with de-selecting the 888's in the Hardware Setup, re-selecting them and then closing and re-opening the session. I don't remember the exact sequence of events, but if I can find my old posts, they will contain them. Unfortunately this fix had to be done every time you open a new session. Honestly, this bug was what finally convinced me to dump my Mix Plus and move up to HD.
I'll post a link here if I can find the info. |
Here's the thread....it's pretty long, but the workaround I mention is explained in the first reply...
good luck http://duc.digidesign.com/showflat.p...ev=#Post804283 |
Tempo change causing midi volume to change plugin output | tgrfox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2011 01:08 PM |
Eleven Rack doesn't change sound output when I change to a new rig | Jlambton | Eleven Rack | 4 | 02-28-2011 11:51 PM |
Weird random noises... | Cerulean | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-11-2007 06:04 PM |
Weird, Random Phantom notes...... | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-22-2007 03:07 AM |
weird error that pops up at random times | JAEPILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-27-2006 07:55 AM |
