Old 09-29-2005, 04:10 AM
natedevillers natedevillers is offline
Default Freezes occuring while loading hardware drivers
Howdy all-
Running WinXP SP2 on a system with P4 (2.8GHz), 512 MB RAM, and a AOpen motherboard (Intel 865 PE chipset). Have a Creative Audigy 2 Z5 (using an ASIO driver).
When installing my MBox with 6.1.1, my machine froze when loading Digidesign Device Drivers. After reboot, ProTools wouldn't completely uninstall from the Control Panel, nor would it repair the existing installation. Had to get RegCleaner to do so.
I've tried installing to the default program files directory, as well as a fresh and defragmened 130 GB partition I created on a SATA drive.
Have tried 5.3, 6.4, and even M-Powered (I know, I know...) all to the same effect.
I've disabled hyper-threading in my BIOS, turned off font smoothing, enabled DMA on all IDE's, checked background services on my processor scheduling, and selected system cache for memory usage.
Am I overlooking something blatantly obvious? The MBox works fine on a Macintosh running 6.4.1.
Any suggestions, comments, questions, or solutions would be more than appreciated.
Thanks.
Old 09-29-2005, 09:29 PM
steve at Your Heaven steve at Your Heaven is offline
Default Re: Freezes occuring while loading hardware driver
This is the wrong forum - TDM uses different hardware and software. Post (or first search) on the appropriate ProtoolsLE forum (use the Jump button at the bottom of this page).
steve
Your Heaven
Digi 002 not loading...it freezes with the words "loading" on the screen teketuco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-09-2012 05:42 PM
HELP!! PT6.1 setup PROB while LOADING HARDWARE DRIVERS Robeeo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-20-2008 03:56 PM
PT freezes when loading session! JBz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-02-2006 04:23 PM
Freezes upon loading….. Fat Peat Digidesign Hardware & Software 1 08-21-2003 08:21 PM
DAE loading comp freezes??? DJED Pro Tools TDM Systems (Mac) 5 08-03-2000 01:25 AM
