PT RAM Usage 389MB - Excessive?
If I check in Windows Task Manager after I load PTLE 7.0, with no sessions loaded, I find that PTLE uses 389MB of RAM on my machine. Is this normal?
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
Re: PT RAM Usage 389MB - Excessive?
From the compatibility pages of every version of Pro Tools 6.x:
The momory requirement for PT7 has been raised to 512; Quote:
sp thats min for the entire system not just PT remember windows uses about 150MB straight off
i just load PT to chack and it was using 163MB of course that goes up once a session is loaded |
Wow, only 163MB. I wonder why mine is 389MB. What buffers size and system level do you use?
I figured out why. It must be the DAE playback buffer setting. I had it set at 8, the highest level. If I use level 2, my RAM usage of PT, with no session loaded, drops to 245MB, and 200MB if I go to level 0.
Now, has anyone any experience at what the difference between these settings are, as a user?
389 is normally right around where I'm at nominally in Pro Tools at any buffer size.
I added 1GB of RAM, for a total of 2GB, and things are much better now. My problem was that I use very memory intensive plugins such as BFD and SampleTank2. BFD is a very high quality drum plugin, but the samples are excessively large. A cymbal decay sample is like 160MB alone... I have a simple session with one instance of BFD, SampleTank2 and Guitar Rig, and the memory usage of ProTools jumps to 1.1GB. No wonder I had pathetic performance with 1GB of RAM. Things are excellent now, and I can even run at 64 samples and level 8 DAE buffers. Given that the extra GB cost like $100, it's *really* worth it.
Excessive Processor Usage and Temperature: Avid 002 & 003 Family Driver | Mike Harrison | macOS | 10 | 08-15-2014 02:54 PM |
Excessive Processor Usage: Avid 002 & 003 Family Driver | Mike Harrison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-28-2013 02:14 PM |
Excessive CPU Usage In Pro Tools with long sessions | dropking | Pro Tools TDM Systems (Mac) | 7 | 04-21-2010 07:23 AM |
Excessive Pro Tools LE CPU Usage even with no session open | jallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-06-2007 03:55 PM |
TL Space excessive CPU usage bug | Matt82au | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-06-2007 08:45 PM |
