Old 04-26-2011, 02:04 PM
perryr perryr is offline
Default Cleaning Up Tracks
New DAW user. I have a session with audio multi-tracks improrted from an anolog tape recorder. Tracks were done 10+ yrs ago, remixing. The recording environment was poor, the tracks are rough, but the music is good.
I want to address the silent area's in tracks.. and what do Pro's do. There seems to be numerous ways to get the job done, but I'd like to learn the most practiced method.
1. Intro's and outro's, do you just cut the dead space out before and after the music, or do you leave it there and just set the start and end points (with fade ins/outs, whatever)?
2. Breaks within the song. Do you cut (and apply crossfades) or use automation, gates or strip silence, or??
3. Tracks where the instrument only plays for short periods (Vocals, and some instruments), do you cut and create regions or do you you leave the track whole and address the dead spots in other ways (these dead spots have bleed as it was performed live).
Appreciate any input.. up to recently I was 100% analog.
8-core Mac Pro, PTHD Native, Avid HD 16x16. Mixing and doing much of the processing OTB.
Perry
Old 04-26-2011, 02:17 PM
daeron80 daeron80 is online now
Default Re: Cleaning Up Tracks
A mix. Whatever sounds good. IMHO, tape hiss helps up to a point. If you have a few tracks, like drums, that have tape hiss throughout already, you can probably cut out the rest of the "silences" with either Strip Silence or manual cutting, depending on the material. Things with long tails can be truncated by Strip Silence, since its minimum threshold is frustratingly high. Things with short decays can usually be cut up pretty effectively with it by setting a long enough end pad.
Whether you need fade ins and outs on the hiss can only be determined by ear. It will depend in part by how hard you end up compressing stuff. I might start without fades and add them as needed. Whether you do fades with automation or fade files depends on your equipment and workflow. If I had a good controller, I'd probably do it with automation. If it has to be done with a mouse, fade files are probably less trouble because you're not flipping track views constantly.
David J. Finnamore
PT 2024.10.1 Ultimate | Clarett+ 8Pre | macOS 14.6.1 on a MacBook Pro M1 Max
PT 2024.10.1 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 04-26-2011, 02:29 PM
Shan's Avatar
Shan Shan is offline
Keep the noise(or at least some of it). Amp hum, preamp noise, hiss, vocal breathes etc are part of the sound. When you cut this stuff out, it seems to sound lifeless and fake in my honest opinion. A trend in many plug-ins these days is an "analog button", which adds a noise floor in many cases.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 04-26-2011, 02:30 PM
fakir_cz fakir_cz is offline
Hi Perry, welcome to the digital world.
As you said, there really are many ways to get the job done. I'd personally cut any unnecessary parts out, because it's simpler and somehow more comfortable to work with than the automation (for this specific task). You can automate mutes, which will get you the same result (except for fade ins/outs, you'd need to automate volume for that, obviously), but with edits, you can immediatelly see where those cuts are and how does your session look like, which can be harder when looking at many automation lanes. So I'd edit. When you cut something out in Pro Tools, the data are still there and you can easily modify the cut, or undo it entirely, so no danger here.
But, from my experience, all those bleeds in live recordings gives the sound a bit different character, that may be desirable in some cases. But this is up to you, of course.
BcA. Tomas Vitha
Sound Designer and Mixer
2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24
Old 04-26-2011, 04:46 PM
It's pretty shocking what most "analog" buttons add to the sound! Print it some time and then gain it up. Pretty nasty in most cases. Tape hiss is vastly preferable. It glues things together.
David J. Finnamore
Old 04-27-2011, 12:54 PM
Thanks for all the great input! I assumed off the git-go that everyone did some basic house keeping, but as in all things audio.. "it depends"! Should have known that to start.
I figured it would be really nice to have the power to get rid of all that stuff I tried hard to minimize with manual fader moves, gates, and mutes. Tape hiss, never figured it would be something I'd like to keep around! But having not mixed down in the digital world, never really thought of the side effects of not having any noise. Of course I have a few tracks with poor bleed and another with poor erase depth on prior passes, so I'll clean those up. But I'll let the other stuff be for now and just do what sounds best for the work.
Appreciate the insight, Perry
Old 04-27-2011, 01:01 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Most of all (what I learned here on the forum), use your ears.
Disk
Old 04-27-2011, 01:12 PM
getz76 getz76 is offline
Right... considering all the work people did to minimize noise in the past... now there are pricey plug-ins so you can add that noise into you mix!
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 04-27-2011, 01:58 PM
guitar486 guitar486 is offline
I usually prefer gates for what you're describing, less editing
----I was thinking of taking a solo in the bridge.
-Nah, I don't think that would sound good.
----Ok, well how about just a series of cool riffs?
Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK
Old 04-27-2011, 03:52 PM
CME CME is offline
This can work quite (quiet ???? ) well. lol Really it depends on how bad it is as to what would work best. And how much you want to remove. I tend to mostly edit out empty spots, but as mentioned leaving some can make parts not sound so.... empty..... maybe.
However if it is just a break in the song. Like a one beat "pause", I'll usually leave that mostly alone, as long as it was played well enough. If you edit it completely clean it can sound really odd. However some times you have to do a little tweaking if something rang out a little long.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
[IMG] code is Off
Cleaning Frank Kruse Artist Series 2 02-24-2012 12:04 AM
cleaning out un used tracks RoyaltyOnline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-10-2007 05:17 PM
cleaning mud pioneerptw Tips & Tricks 19 01-07-2006 09:33 PM
Cleaning vocal tracks JGutta Tips & Tricks 3 05-02-2005 02:45 PM
OT: Cleaning up Win XP??? nikki-k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-13-2004 02:38 PM
