Old 04-16-2021, 10:22 AM
TheSoundshaper TheSoundshaper is offline
Default Quicktimes import changing the session frame rate.
I came across a really annoying pro tools issue recently. Pro Tools has always alerted you on import if a quicktime doesn't match the session frame rate. You get the frame rate in red on the video track. NOW it will import the quicktime with no alert AND change the session's frame rate to match the quicktime! I'm on 2020.11.00. Its a new system so am I missing a setting to go back to the old way? Thanks!
Old 04-16-2021, 02:07 PM
Default Re: Quicktimes import changing the session frame rate.
In the session setup window where the "Timecode Rate" drop down menu to set the session frame rate is, there is now an option in that dropdown menu for "Follow Video Frame Rate". Unchecking this should restore the previous behavior.
Scott Gatteño
HTML code is On
Can't import video when frame rate not the same as the current one Rockman413 Pro Tools 10 2 11-08-2012 08:52 AM
AV sync problem in delivery due to Pro Tools changing frame rate of video anthony b Post - Surround - Video 14 05-16-2010 12:59 PM
How do I import an omf with a frame rate of 59.94? AudioAlchemy.tv Post - Surround - Video 2 09-08-2007 03:55 PM
Same video frame rate still won't import - too often anyway Farmer Dave Pro Tools TDM Systems (Mac) 3 07-23-2007 07:22 PM
7.2 BUG - Video import w/different frame-rate Charles Deenen Pro Tools TDM Systems (Mac) 4 08-08-2006 01:23 PM
